Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer noise Maytag atlantis mdg7460aww front load gas dryer. One day it just started squeaking really bad while running. It will go away from time to time. I removed the front panel and looked around. The belt seems fine. It sounds almost like metal on metal. Any idea what could be causing this?
  • 864 Answers
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Posted on Jun 03, 2009
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is making a very loud noise. it is still drying and turning. what could this be?
heatman101
Mar 15, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My Atlantis dryer makes a clunking sound when running. It seems as though it happens when the same spot on the drum passes a certain spot on the left side of the dryer.
Hi, Belt is going bad... has a chunk out of it...
heatman101
Feb 10, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Tub is not spinning and making a squeak noise
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101 ..
Nov 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Drum squeaks during drying cycle.
heatman101
Oct 26, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
heatman101
Aug 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG PERFORMA ELECTRIC DRYER SQUEEKS BADLY WHEN RUNNING. METAL ON METAL. DRUM IS WORN
If the metal-on-metal squeak is coming from the front of the machine, you need to replace the glides. These are plastic pads that support the front of the drum around the door. The rim of the drum slides over them, and they eventually wear through.
Mar 07, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer squeaks
THE BEARING ON YOUR TUB IS GOING OUT AND NEEDS REPLACING
Oct 14, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
244 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
