Question about Glyph NetDrive (ndfw1b-80) 80 GB Hard Drive
Power adapter question-netdrives 80 gig
What is the power adapter that comes with this unit-I've mixed mine up!
CaNT FIND POLARITY SYMBOL ON WIRELESS_N_TRAVEL ROUTER
Use a multimeter to measure the voltage on the adapter plug and you can determine the polarity at the same time.
Sep 09, 2012 | Computers & Internet
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
Netdrive 250 bulb
The bulb is a blue LED (light emitting diode device). this LED will be soldered onto the circuit board.
These LEDs last a very long time and don't normally burn out. Some other component maybe faulty.
May 14, 2010 | Glyph (240295) 250 GB USB Hard Drive
My wd passport will not work on my ibook g4
Is his the same exact hardware? its possible that his may have the power necessary to run it. Have you tried it with anyone else besides yours and your friends man, being that one friend.
Jul 07, 2009 | Western Digital Passport WDXML800UE...
Computer will not recognize my 120G Glyph Netdrive when connected
check for the power and data slot sometimes wires are loosely connected also try to find appropriate driver as per the make of hard drive
May 08, 2009 | Glyph NetDrive (ndfw1b-80) 80 GB Hard...
My drive smells like it is burnt out
I would say the drive overheated & fried since a different drive works it is not the computer. Sorry. Hope this helps.
Dec 31, 2008 | Glyph NetDrive (ndfw1b-80) 80 GB Hard...
PS3 not powering up but has blinking red light.
Tell Sony !! I did now im gettin a new 80 gig (lost all my online data tho!)
but hey im gettin a new unit plus there sending me cod 5 cos thats stuck in the ps3
sont no about this fault an its not fixable (smoked mother board!!!)
hope this helps..
ps
mine was outa warranty.(60 gig)
Nov 17, 2008 | Sony Playstation 3 (PS3) Console
80 gig maxtor
change hard board or
change your cables (date & power)
Oct 27, 2008 | Maxtor Hard Drive
Glyph NetDrive (ndfw1b-80) 80 GB Hard Drive Logo
47 people viewed this question
Top Glyph Computers & Internet Experts
Marcin
_-__-___-_
_-__-___-_
Are you a Glyph Computer and Internet Expert? Answer questions, earn points and help others
