NO DISPLAY LIGHTS
I HAVE A YAMAHA RX-V493 AMPLIFIER AND WHEN I PUSH THE POWER BUTTON NOTHING LIGHTS UP.I CHECKED THE FUSE AND IT WAS GOOD SO WHAT SHOULD I DO NEXT?
4 Suggested Answers
SOURCE: Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Posted on May 05, 2008
petraman7
  • 1175 Answers
SOURCE: YAMAHA RX-V630 WON'T POWER ON NO CLICKS
If the unit is like the Rx-570 , the display bulbs have quit.
Theyre 14 volt lamps about 0.1 wide x 0.250 long (white wire leads)
Located in the plastic shroud behind the display
Posted on Mar 24, 2009
  • 39 Answers
SOURCE: Wont do anything
Sounds like the stanby transformer has gone.
This is the transformer that turns the main transformer on and powers up the unit.
Cant be certian though, could be a host of other things.
Posted on Jun 16, 2009
How do I reset a yamaha rx-v493 receiver?
Disconnect any speakers from it and see if it still turns off. If it doesn't, then you have a shorted speaker or speaker wire. If it does still turn off, then it would need to go in for repairs.
Jan 09, 2013 | Yamaha RX-V493 Receiver
Just simply, what speakers do i use with a YAMAHA RX-V 493 RECEIVER
ANY that are nominally 8-ohms and can handle around 100W RMS. No other limitations. That's why they have specs.
Jul 18, 2011 | Yamaha RX-V493 Receiver
I have a yamaha rx-v493 reciever and no speakers what should i get that wont blow and wont empty my wallet
Of course you know you're asking a question that could attract more opinion than useful facts.
If you watch the volume and buy efficient name-brand multichannel speakers with REAL bass-handling capacity you'll probably love the sound without endangering your speakers or your ears.
As it is distortion more than raw power that kills speakers you need to keep away from pushing the amps beyond their RATED power (roughly 70 wpc into 8-ohms, @1khz, <.04%THD. I'm a little concerned that the spec in the manual qualifies it as only 1khz instead of the ore honest and meaningful 20-20000 hz it states for the RX-V393.
An under-powered amp will kill speakers faster than an over-poweredf one as it will enter its high distortion region much sooner.
Play-it-by-ear is good advice. If the amps sound strained, back off the volume.
Your room size will play a huge part in the perceived loudness while your household's aesthetic sensibilites will limit the size and visibility of the speakers. Compromise between form and function is almost guaranteed.
Being a long-time audio enthisiast/collector, set in my ways and unwilling to bow to appearance at the cost of the sound, I use full-size (70's and 80's era) Bose speakers (901's and 301's) throughout the room and augment them with a couple of huge subs and large Kenwood 777 center speakers. It ain't cheap or pretty but it rocks movies and music.
I would recommend you do some research into "home theater speaker recommendations" and read some user comments for the various offerings out there. You'll be in a relationship with your A/V system for a long time. Take the time to get it right.
Jan 17, 2011 | Yamaha RX-V493 Receiver
Yamaha rx-v563 just stoped working no power no displayed nothing have removed plug and tried other power points still nothing help
Check the internal fuse inside the unit. If it goes again, after replacement, get back in touch with us. If OK check the transformer and the power switch.
Mar 01, 2010 | Yamaha RX-V563 Receiver
Wont do anything
Jun 16, 2009 | Audio Players & Recorders
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
Mar 23, 2009 | Audio Players & Recorders
Yamaha AV Receiver Amp RX V493 Bose Speakers have stopped working
If you already check the output of your Amplifier is good then the problem is the speaker.Check the resistance of the speakers, if no resistance, then it already busted,or maybe the connection of speaker wire to the cone is loose or crack try to check it out.Then if you check already and it tight no crack ,then the problem is in coil winding of the speaker,it needs to rewind...
Hope this may help,
Regards,
VOTIT
Don't forget to rate;
Jul 29, 2008 | Audio Players & Recorders
Yamaha RX-V461 receiver audio
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Dec 15, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
