SOURCE: 2003 Harley Davidson Sportster 1200 Custom Tachometer kit
The only idea that i can come up with is that you dont have a good ground..or the guage was bad when you bought it..i hope this..Keith
hold key fob until signals flash,check speedo for solid key light,then try...if it still does the same thing,battery could be too low(will cause this also)
SOURCE: 2001 Harley Sportster 1200 headlight not working.
ok youve done alot great job, now trace until you get voltage. follow that wire back until you get voltage in other words. if you have any kind of diagram your problems solution is sooo simple.
i am a technician btw.
SOURCE: 1993 harley sportster 1200 headlight quit working
could be a bad ground in the head light bucket or the jumper from frame to the triple tree
SOURCE: i have a harley 2001 1200 sportster title says
I can scan you a copy of the wiring diagram for a 1999 model. Most wiring changes are very minor on the bikes from year to year. Contact me at [email protected] Make sure you remind me of what you need.
Good Luck
Steve
Testimonial: "very glad to receive a diagram"
