Water leaking from coil pan that is cracked down center
Coleman evcon furnace leaking water from coil pan that is cracked down center.age 11 yrs old
  • ACSvcTechFL May 11, 2010
    Honestly you are better off replacing the system an 11 yr old Evocn systems drain pan costs $150 plus Labor and refrigerant if needed you look at nearly $800 for an 11 yr old system when you can get new ones installed for around $3,00, and it will help you on your electric bill
  • steve
    steve May 11, 2010
    Replace the coil pan.
Maybe you can fill the pan a little with some type of sealent, like resin, that might seal the crack pan..
Posted on Jul 15, 2009
    President:
  • 1,902 Answers
Buy a new pan. Once they are broken they cannot be sealed due to the fact that they will not level out and will have problems with water going in other directions then to the train pipes
Posted on Jun 03, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
My ac unit is leaking through the coil box, I cleaned the drain, but it still leaks from the side of the box. Could it be cracked? the unit is 9 yrs old
Could be a cracked condensate pan. this may require replacing the pan or there are sealing sprays on the market which you can buy at HVAC stores.
Dec 11, 2012 | Weather King Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
