Question about Mitsubishi WS-48311 48" Rear Projection Television
S-Video on the blue screen
I bought a Mitsubishi WS-48311 and I've had it for some time. My son plays Xbox and always plugs his red white and yellow cables into the front of the tv. Now recently when I try to turn it to cable which I hardly do. It comes up with a blue screen and says S-VIDEO and I have nothing plugged in there. HELP!
  • Anonymous Mar 15, 2014
    store e tv toshibaplease need help about my son he put the cable electrecity for the labtop DC 19V to the hard disk store 12VThe problem is the screen for the store tv not appear all the time it is red
  • 1,694 Answers
Menu has input selection to turn on/off or name video inputs.....T.
Posted on Oct 24, 2007
Red-white-yellow inputs don't work
what model of computer do you have, what video outputs do you have on your computer, if you have an s-video out on your computer, I would use that with the tv
Mar 02, 2013 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi, model # WS-48311. The red and blue are constantly way off. This is especially apparent when text is on the screen. I made sure the convergence was lined up, but still have the problem....
If the text bows way out of proportion you may in fact need new convergence IC's, part # for most of these is stk392-560. in some cases a resistor in this circuit will change value causing misalignment of convergence. you should not be able to get the convergence perfect if either condition exist. I have encountered cold solder connection in some of these older projo tv's.
Nov 29, 2010 | Mitsubishi WS-48311 48" Rear Projection...
How to hook up ur xbox 360 to ur tv to play ur xbox 360
if your using the hdmi cables you have to plug in the green, blue and red cables into the corresponding sockets on the tv, the plug the red and white ones into sockets which are not in the same area as the normal red white and yellow cables, there should be a row of sockets at the bak of your tv:
Dec 22, 2009 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Dose not show on screen anymore. son said he was asked to change something. he did. cant play anymore.Must be some setting that was changed. Cant get it to show on T.V. TV says unsupported format. HELP
Not sure what you are talking about, this is a bit vague..... try this, on the back of the xbox there is a switch on the plug that goes to the TV, if the TV is not HI-DEF and you are using just the red + white + yellow plugs, then switch to TV, if your using the red + white + blue + green + red then switch to HDTV.
Your Son could have also switched a setting on the dashboard to use HI-DEF, if he did, maybe switching back the TV mode on the TV out plug may correct the issue.
Kids love to play with things! lol...
Sep 08, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Component color turns yellow
when you say color. Do you mean gray scale like what if you turn off the color completely?? Does the picture look B&W? need to know this?
Jul 01, 2006 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
