Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
No picture or sound, flashing standby light, will not turn on
I have a Sony KV-36HS500 Great picture and sound, right up to two weeks ago, now when you turn it on no picture, sounds like it try's to light up but all I get is 6 flashes on the stand by light. I see on the web lots of other people having the same problem with this same TV! When you try to turn it on you hear clicks and then have the standby light flash and it won't turn on. From other posts elsewhere it sounds like a blown capacitor on the power board. If this is a problem a bunch of people are experiencing shouldn't they post a factory recall? At any rate, one post stated that they received help from a tech on this site on how to fix it herself! So I'm wondering if you can help me to do the same. I've got the exact same problem. The TV started behaving this way a couple of weeks ago. I would unplug it at night and it would usually work the next day when I plugged it back in and turned it on. Now, this does not seem to help and it just gives the 6 flashes now.
  • 643 Answers
Sounds like powwersupply issue. repair is usually reasonable from reputable repair shop. id say around 150 - 250
Posted on Jun 03, 2009
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No sound or picture-just clicks when turning on-standby light flashes 5-7 times
it is problem in power supply.may be some of components are demage such as capacitor or diod and mosfac .Repear it by a good technician in your area.
Nov 22, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No picture or sound
6 blinks usually means a loss of the horizontal signal. This can be as simple as a bad capacitor or jungle IC. I'll look up your specific model, but do you intend to repair this yourself? If so, please update this and I'll provide additional details and instructions.
Dan
Mar 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My KV-36HS500 won't turn on it sounds like it wants to,but no picture,and standby light flashes 7 times,pauses and flashes 7 times again
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron
HI!
Observed the standby light for flashing;becaused there is diagnostic code for flashing;
If ever there is no sign of standby light,your power supply is depected maybe a blown fuse,if you know how to open the back cover,you can replace that fuse,it is very easy (DIY) do-it- yourself.
I will follow the diagnostic code;
Hopes it may help you;
Regards,
VOTIT
Sep 06, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby mode and can't get tv to work
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Thanks,
Dan
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
254 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
