Question about GE 24 in. GSD4030Z Built-in Dishwasher
Washer fills, but cycle doesn't start
Press start, and the washer fills with water. But the pump never kicks on. There's just a humming, then a clicking sound, then a faint smell of maybe burning??
  • 6,784 Answers
This is motor failuer. replace asap. the smell is the motors copper windings heating up the internals of the motor Housing.
Posted on Jun 03, 2009
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Even humming sound made when washer starts continous
Most likely a motor or solenoid has a loose coil or its magnetic field is vibrating a nearby piece of steel. If it hums all of the time except when the washer is filling, it is the timer or main motor. If it hums only when the washer is filling, it is one of the water valves (you can isolate by selecting hot or cold instead of warm for one of the cycles).
The timer motor is on the control panel right behind the cycle select knob. The main motor is under the tub. If the main motor is humming, it may be overloaded, but in that case, the humming should diminish as the motor gets up to speed.
Jan 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool dishwasher will fill with water but washer cycle wont kick in just makes a humming noise
Your pump could be jammed or plugged. Make sure the grate in the bottom of the washer is clean. If possible, pull it out and look under it to see if there is anything in the hole.
Jan 08, 2011 | Whirlpool Dishwashers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Dishwashers Logo
256 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
