Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My westinghouse cabrio washer displays Ld error code. I put it on rinse and drain and now it is not doing anything...just humming. It will not drain, turn off or anything. I have to unplug it in order to turn it off.
ngfam1
  • 639 Answers
SOURCE: i have a cabrio washer
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
SOURCE: Cabrio Washer LD error code
same problem here
Posted on Oct 17, 2008
tzweeb
  • 318 Answers
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
SOURCE: wont drain says Ld
I found that this washing machine has an electrical pump that drains the water, not like other machines that use the belt to turn the drum and also the pump at the same time. This motor is a low voltage motor/pump and anything that gets caught in the pump propeller will cause the draining to stop and bring up codes like Ld (long drain) Before calling in a service man try inspecting the pump first, tilt the machine to the side and take out as much water as possible, ideally you want all the water out of the machine. Next lay the machine on its side and remove the bottom plate, you will see four screws holding the black plastic pump housing onto the motor with the hoses attached to it (no need to remove the whole pump) remove the screws and you should be able to see inside the pump, if there is anything rapped around the pump shaft or propeller you will need to remove it. Replace the housing and make sure you secure the screws, replace the bottom plate and try the machine. hope this helps.
Posted on Jul 14, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
Jun 07, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
300 people viewed this question
Dan Webster
Dan Webster
Sal De
