Question about Garden
John deere145 lawn tractor starter just whirls
Just out mowing turned off tractor then went to restart starter just spins but it will not engage just spins, Bendix ? gear?
  • bilalinmd
    bilalinmd May 11, 2010
    Or if it is, the bendix gear probably gave up all it's teeth. Plastic bendix gears have this problem like the plague. Could you remove the motor to check?
    Bilal Hassan
    Clarksville, MD
  • Dwain Pippen May 11, 2010
    What engine is on the mower? It sounds like the bendix is not being thrown up to engage flywheel.
  • 218 Answers
Hi..my name is Keith..and there is 3 things i can think of....1..is the starter or the bendix....2. is bad teeth/gears on the flywheel or 3.. the battery voltage is low..i hope this will help..if not..please write me back
Posted on Jun 30, 2009
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
John deere shuts off when mowing
sounds like you have sensor gone wrong.try to check what sensor you use thru your manual
Jul 17, 2014 | John Deere 1966 110 Lawn Tractor 7 Sprayer...
Bought a Toro Timecutter SS 4235 about a month ago. Mowed the lawn about 5 times. When I turned it off after the last mow it made a funny sound. When I went to start it today I got nothing. Checked the...
Could be your battery shorted install known good battery, make sure key off. Install positive cable then slap negative cable to negative post if no spark then install. Sit on tractor and try to start as usual if you have problems starter circuit probably starter bad. If not try engaging blades if problem, pto wire grounded or clutch winding bad. If everything OK then shorted battery.
Sep 22, 2017 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
Unable to start by-passed start soleniod,went direct to starter with 12v. starter would not turn. Engine is free.
If you went directly from the battery to the starter & the srarter did not turn-spin -or whirl replace the srarter.
May 01, 2011 | Garden
I have not used my lawn tractor for a long time. now it just CLICKS when I try to start it.
battery does not have enough charge to spin the starter, you might be able to charge it up. try jump starting from a car battery then mow your whole lawn without stopping. if it restarts after that you are good to go, if not go to walmart and spend 25 bucks on a new battery. replace the gas first.
Apr 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stopped while mowing...tried to restart...nothing.
I am having the same problem. The PTO in engaged and won't relase. The engine won't turn with PTO engaged, you need to disengage the blades to restart.
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
198 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
