Question about Lexmark X1240 All-In-One InkJet Printer
Paper tray (holder)
The tray has broken off.  What can I do to get it fixed,
  • 1,027 Answers
Contact Lexmark customer service; it may be cheaper to buy a new one.
Posted on Jun 14, 2008
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Well, I did everything your steps said to do but that did not fix the problem. When all is done and turned back to online, the printer buzzes and flashes the 13 paper jam again; however, there is no paper...
If your printer makes a load clicking sound and then shows "paper jam" then the problem is a broken drive motor gear. This is a very common problem with this unit. The nylon gear on the drive motor becomes brittle due to the age of the unit and cracks. When this happens the gear teeth do not mesh with the other gears and you get the grinding and clicking sound, and no paper pickup. You can change the gear yourself. The drive gear is available here:
And here is a video showing how to install it:
Jan 28, 2011 | HP LaserJet 4p Printer
3110cn paper tray has small white plastic clip which has broken off on left side when pulling tray open. Now window states load paper tray. Any fix or where a paper tray can be purchased. Dell does not...
I've seen this problem before on Dell 3110/ 3115 and other versions of the same printer chassis.
The broken part prevents the paper being 'lifted' to the pickup roller and paper out sensor, so it thinks ther is no paper in the tray, and can't pick it up.
Look on 'the usual internet auction site' (as ever), and you'll probably find one (I'll list one in the next couple of days).
Jun 08, 2010 | Dell 3110cn Laser Printer
Paper tray holder paper size stuck at a5. will
Did you ever get it fixed? Mine is having the same problem!
Apr 22, 2010 | HP LaserJet 3600dn Printer
The paper roll holder is broken on one side. Can
For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
Mar 25, 2010 | Office Equipment & Supplies
Brother MFC3360C paper drawer will not open
remove the paper tray
remove the jam clear cover in the back.
Lift the Pull In Roller
Holder Assembly with a
credit card.
be careful not to lift too much
While lifting the Holder
Assembly, pull the tray
free from the machine
lubricate the right side with a little bit grease where the vshape is located on the tray
Apr 16, 2009 | Brother Multi-Function Center MFC-3360c...
Paper feeder not working properly
did you load your papers the right way? Look on your paper tray. There should be a few snaps right on the sides of your paper tray. Make sure you use those snaps to keep your papers confined in your paper tray
Mar 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Laserjet 4700 Tray 2 stuck will not pull out.
You possiblely have something loose in the tray or something broke. Find something metal and thin, like a hack saw blade, and stick it through the slot between the drawer and printer and see if you can feel the obstruction, and if so try to move it out of the way. Something is catching on the printer frame and drawer.
Feb 27, 2009 | HP LaserJet 4700 Printer
Paper jam problem
Hi, if you are having the paper jam issue , then unplug the power adapter and remove all the papers from the paper tray and if you closely look inside the input paper tray you will find rollers , move the rollers with your finger tips. open the printer cover to the extreme left you will find the cartridge holders , move the holder from left to right a couple of times , behind the cartridge holders you will find a transparent strip which is inch wide and is inch wide and firmly connected at both the ends, use a damp cloth and clean that strip . lift the printer an#d shake it firmly turn the printer upside down and gently tab on the base , look for any obstructions.
Try all these steps and if there is an issue then you have to purchase the new printer.
good luck :), let me know once you perform all these steps
May 01, 2008 | Dell 924 All-in-One InkJet Printer
Hp colouer laserjet 4500n printer 2nd paper tray dont work when i clear the printer memory it work properly for few day in this printer an error shows drum life low change the drum and tool kit
I would definitely suggest ordering the drum life kit and replace that. A lot of times the tray comes undone from the paper tray holders causing the rollers to not be able to pickup paper. Be sure all the plastic holders are snapped into place on the right paper size setting and check the rollers for dirt, glue or wear.
Jun 07, 2007 | HP LaserJet 1020 Printer
Lexmark X1240 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
