Question about Ricoh Aficio 450 Copier
Brother mfc-260c not recieving fax, has dial tone.
Brother mfc-260c when press hook have dial tone, but have been unable to recieve fax.
  • 37 Answers
Im not very familiar with that that model in particular. I would check to see if the is an auto recieve button on the control panel or in the fax settings. Just a thought not an absolute solution.
Posted on Jun 07, 2009
Hi i have a brother called MFC 8660DN, he is not recieving or sending any fax since this morning and i can't find the problem.
Try these things below to narrow down the problem.
  1. Plug a standard phone into where the fax line is plugged into to check for dial tone. if you have dial tone try replacing the phone line between the wall and fax. If not you have a phone line issue.
  2. Make sure the printer is actually responding to print commands from a computer, this could indicate a hardware issue if it does not.
  3. Check the ink levels. If the printer thinks it is out of ink then it will not print faxes.
I hope this points you in the right direction Regards GM
Apr 26, 2011 | Brother MFC 420CN All-In-One InkJet...
Fax machine isn't able to recieve or send anything
Make sure there is a dial tone on the phone reciever. If there is not check the connections, the cord could be damaged or disconnected. If there is, check the Recieve mode.
If not call Brother support - its free
Mar 31, 2010 | Brother IntelliFAX 2800 Laser Fax
No dial tone to fax documents with Brother Model
This issue was addressed previously by another FixYa expert. Read the entire post before attempting any repairs. Hope this helps
See:
http://www.fixya.com/support/t1234332-mfc_440_cn_out_memory
Dec 11, 2009 | Brother MultiFunction Center MFC-440CN...
My fax onmy mfc is beeping when i dial and press start there is no dial tone when i press hook is it connected?
If it is connected you would hear a dial tone when you press hook. There are 2 possible places to connect the phone line, the proper one has an L on it and the other a picture of a phone that is for a phone or answer machine.
Nov 18, 2009 | Brother MFC-5440CN All-In-One InkJet...
Fax machine won't send or recieve faxes
press the "on hook" dial key. this should let you hear a dial tone. If you don't hear a dial tone, then it is probably the phone line and not the machine. You may have to call your telephone company.
Nov 26, 2008 | Ricoh Aficio 450 Copier
I am unable to recieve a fax
have you tried a firmware upgrade, depending what happens with the fax tones depending where the fault is. can you ring into the machine? other thing to try is put a handset in the line and dial out or listin to the line?
so many things come in with problem sending and recieving faxs. have you tired putting on ECM mode?
Oct 21, 2008 | Brother Office Equipment & Supplies
Brother MFC-260C How do edit phone numbers set up in short dial
i have misplaced my disc for installinig my brother MFC-235C
MFC-260C. any help with an answer to installing my printer would be much appreciated. thank you, tania
Aug 20, 2008 | Brother Office Equipment & Supplies
I can recieve or send faxes!
The phone jack is missed up after all
Jul 23, 2008 | Brother MFC-8220 Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Will not receive or send faxes
WHEN FAXING BOTH MACHINES NEED TO RECOGNISE EACH OTHERS NUMBERS (NO NUMBERS CAN BE BLOCKED) AND YOU HAVE TO PROGRAM YOUR NUMBER INTO YOUR FAX MACHIE BY RUNNING THE INITIAL SETUP
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Ricoh Aficio 450 Copier Logo
137 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
