Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
Problem replacing light bulb in GE Profile 1490
I am having problems changing light bulb in my GE Profile Spacemaker Oven JVM 1490. I bought a bulb that I read on a post as working for the 1790, but I didn't realize that until today, when I tried following the instructions for install. Any help would be appreciated! And please tell me I don't have to take it off the wall! :)
  • 2 more comments
  • laular02 Jun 03, 2009
    It is my inside light bulb, and it is JVM1490SH01. I think I have located where to change it at, but I am afraid to pull the old bulb out, as I don't have very great access to it.
    Thanks.
    It's the interior bulb, and it is JVM 1490SH01
    Whoops I didn't think the first one posted. Sorry.
  • William Miller
    William Miller May 11, 2010
    Which bulb - the inside cavity light or the cook top light?
    What is your full model number, including suffix, from the tag inside the oven?
    It will be one of these:
    JVM1490BD03
    JVM1490BH01
    JVM1490BH02
    JVM1490CD03
    JVM1490CH01
    JVM1490CH02
    JVM1490SD03
    JVM1490SH01
    JVM1490SH02
    JVM1490WD03
    JVM1490WH01
    JVM1490WH02
    JVM1490BD002
    JVM1490BD003
    JVM1490CD002
    JVM1490CD003
    JVM1490SD002
    JVM1490SD003
    JVM1490WD002
    JVM1490WD003
5 Suggested Answers
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
jsrock516
  • 5911 Answers
SOURCE: how do you replace the handle on a ge Space Master Oven JVM 1490 BD 003
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Posted on Apr 28, 2009
  • 70 Answers
SOURCE: JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Posted on Aug 18, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a GE Profile Spacemaker XL Sensor Mod # JVM
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Oct 10, 2009
Testimonial: "Although I received this solution after I had called in a technician and paid $100, your instructions were right on and exactly what he did. Doug"
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
I have a GE spacemaker microwave oven model JVM 1440. A bulb blew and when I went to change both over the stove bulbs stay on all the time. What is the problem and what should I do.
there is some kind of circuit board damage. carefully check for burned foil paths on board; around where the relays are. if so, you may be able to "bridge" the broken foil paths with solder. just unscrew the bulbs in the meantime.
Aug 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JVM-1650-ch01 space saver oven hood and the oven light will not turn on. I've replaced the bulbs and the read out says that the light is on but the loght will not turn on by pressing the...
Sorry to read about your problem, I hope this helps you out.
The main control board controls the lite with a relay,, the relay is defective or you may have a broken wire
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
472 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
