Question about LG LRM1250 Microwave Oven
Lrm1250w/01 lg microwave turns on and runs but will not get hot any ideas I have the very same problem. The microwave shot craps. I too searched the internet for a fix. I suggested the purchase of a new microwave.
  • LG Master
  • 19,396 Answers
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Jun 02, 2009
I have a Siemens Microwave Model # HF36V305/01 and the fan will not shut off? Any ideas as to how to fix this problem?
Microwave Automatic Vent Fan Operation - YouTube
? 2:07
https://www.youtube.com/watch?v=6LoK1geGXbQ
Aug 1, 2011 - Uploaded by GE Appliances
This video explains the operation of the automatic vent fan feature on over the ... We have a Hotpoint Counter ...Missing: siemens ‎hf36v305 ‎01
Microwave vent fan won't turn off - Appliance Repair Forum
Nov 26, 2015 | Siemens Microwave Ovens
How to change fuse for lg lrm1250W
Hello
Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
Oct 05, 2011 | LG LRM1250 Microwave Oven
My LG Microwave (LRM1250W) does not heat all of a sudden
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p]][p
Feb 17, 2010 | LG LRM1230W Microwave Oven
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
Sep 27, 2009 | LG LRM1250 Microwave Oven
Does not heat up
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 01, 2009 | LG Microwave Ovens
Lg microwave oven mc9283jlr error=e01
My LG microwave heating is OK but the grilling only not working
Jul 06, 2009 | LG Microwave Ovens
Lg microwave exploded hot water on my face
It's rare, but obviously can cause serious injury!
Your manual should address this, or for more on what causes this, read this article.
Jun 14, 2009 | LG LMV1650SW Microwave Oven
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
Solution .....purchase a new micriwave other than LG.
Im not impressed with our either!
Feb 18, 2009 | Microwave Ovens
LG LRM1250 Microwave Oven Logo
400 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
