Question about Aspire Acer 7520-5071 Notebook
Acer 7520G games problem...
Major problem of this laptop is that when i am in a game (absolutely all), the image and the sound starts to take place, to freeze, then turn the fan and simply must get out of the game. I changed the CPU speed up and worsen the situation worse and then I changed the CPU speed to a minimum, you can enter the game without waiting too long, but after a few minutes the same situation. Please much to help me. Please find me a solution as soon as possible. THANK YOU!
  • alex_mincule Jun 03, 2009
    Thank you.i will try.
  • Aspire Master
  • 13,433 Answers
Hey, its overheating, not much you can do about it, try one of those cooling pads. Did a little modification on mine back in the day, I put a cpu cooler from a desktop computer on top of the video card on the laptop, happened to be in a good spot, wont be a good idea for most laptops.
Posted on Jun 03, 2009
I have a acer aspire 7520g i have replaced the motherboard now my cam won`t work even tho i have downloaded and installed the drivers
The WEBcam is located in the laptop lid above the LCD screen. Check the cable from the WEBcam is firmly attached to the motherboard.
Apr 21, 2013 | Aspire Acer 7520-5071 Notebook
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
My Acer Aspire 7520G gives, most of the time, no sound. Problem with the Acer Aspire 7520G 17.0" Laptop Acer Aspire 7520G gives, most of the time, no sound or audio device in windows 7. 2 days ago I...
Try installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
My acer aspire 5738g keeps shutting down when i'm
Sorry you are having troule. It sounds as if it is getting hot and protecting itself. Games are very cpu intensive and this causes heat. The cheap fix is an under cooler. This is a cooler the laptop sits on. I have seen them at Best Buy for under $20
Apr 07, 2010 | Acer Computers & Internet
How I may use Bluetooth on Acer Aspire 7520G?
Hi there, please follow the instruction.
1. turn off Bluetooth button.
2. run your Acer driver disk & install the Bluetooth
device. After a while your laptop asking you for turn
on your Bluetooth. Press the button of Bluetooth. It
will installing then. After a while another message
will come in front of you that, Bluetooth device
installed & ready for you.
You may also watch the link for some an idea about setup a Bluetooth.
Thanks & waitimg for your feedback.
Feb 12, 2010 | Computers & Internet
I have a mini Acer Aspire One. the sound was
if you r hearing the same distortion in headfones then the problem is in the sound card of the laptop.
purchase the external usb sound card
Dec 05, 2009 | Acer Aspire One PC Notebook
My acer aspire 5520 laptop stalls during games. If I'm playing a game such as backgammon or rummy the timers on the games keep going but the game seems frozen, I can't make any moves. Any ideas why this is...
Sounds like an overheating issue to me. Clean out with canned air. Second guess would be an issue with the game itself on your computer. I would run a check disk to make sure you don't have any corrupt files.
Jul 03, 2009 | Acer Computers & Internet
Keyboard Replacement Instructions for Acer Aspire 7520g
if ur key board is guranty period than ur keyboard is replacement by service center oterwise warrnty period only repaired by service center.thank u
Jun 03, 2009 | Computers & Internet
Aspire Acer 7520-5071 Notebook Logo
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
Mark Dewar
Joe Goldman
Joe Goldman
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
