Question about AT&T Blackberry Curve 8300 Smartphone
Camara on blackberry phone does not work
When I try to use my camara on my Blackberry a message saying "Could not start the camara. Close other applications and try opening the camara again. No applications are open? i tried that and it did not work
  • 407 Answers
You can clear the memory by doing a soft reset - Hold down Left Alt, Right Shift and Delete keys simultaneously for a couple of seconds which will clear the memory.
Let me know how you get on with the above.
Posted on Jun 03, 2009
Please help my fone don't wanna take pics or vidio it shows close apps than try camara again
And did you close any apps already? I think the phone wants to make some memory free, for the camera app to work, and to sore the pictures or video you want to shoot. Rebooting, does not close apps.
Oct 01, 2014 | RIM Blackberry Curve 9320 Smartphone -...
My camera for my blackberry 8520 is not working a message saying: close all applications and try again keeps poping up
This is a firmware related issue and can only be solved by either formatting or resetting the phone.
Also, you can upgrade the firmware and it should work fine.
If it gives problems after that, then you might need to get a replacement or send it to the company for repairs.
Hope this was useful?
Jun 12, 2011 | RIM BlackBerry Curve 8520 Smartphone
When i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
when i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
Oct 10, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8330 camara problems only see a purple or sometimes green screen...& not able to take pictures...
It occurs when Camera application gets corrupted.
Kindly install the Blackberry device software using Desktop Manager application and then try.
To Install Blackberry Device Software
1.Connect the BlackBerry smartphone to the computer and open
BlackBerry Desktop Manager application
2. Double-click Application Loader.
3. Click Next to start the installation process.
4. Type your BlackBerry smartphone password, if prompted, and click
OK.
5. Select the check boxes next to the names of the applications you want
to load, and then click Next
6. Click Advanced, and then select the check boxes beside Erase all
application data and Erase all currently installed applications
7. Click Next.
8. Click Next > Finish.
9. When the process is completed, the message, The loading operation
was successful will appear. Click Close to return to BlackBerry
Desktop Manager.
Please contact your Service Providor of SIM card for further assistance on the same.
Nov 09, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Try turning off the phone and then removing the battery for a few minutes. Replace the battery and then then let the phone reboot, it should work fine after it reboots.
May 31, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cannot email with my 7290
Call your network provider to have your blackberry 7290 enable. This is free of charge and will get the IM messaging workings, but if you want to setup email etc, you will need to subscribe for email and a data plan which will cost about 19.99.
Oct 31, 2008 | RIM BlackBerry 7290
AT&T Blackberry Curve 8300 Smartphone Logo
108 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
