Question about Black & Decker String Trimmer Cordless 12" 18V
String Runs Out
Spool seems to run out each time I use it--after about 30 minutes of trimming. I don't keep the trigger pressed or anything like that--just go to a strech of grass, press the rigger and trim, then move on to the next section.
  • 41 Answers
You are most likely keep bumping the head on the ground, causing the string to unwind. Hold weedtrimmer off the ground.
Posted on Jun 03, 2009
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
String does not seem to feed automatically frequently have to take the spool out to re thread through the lottle holes
These things can be very sensitive with how the sting is coiled on the spool. Take your time and try to get it perfect. Look at the pre strung replacement spools for an example. also inspect the lever, usually under where the spool sits. Make sure its not to dirty and moves freely. After that when you want it to feed quickly pull and release the trigger a couple times. If you dont want it to feed the when you pull the trigger be sure to maintain how far you have it pulled back, then release it a little slower than usual. Lastly wait a few seconds before pulling again. If this doesnt work the lever may be worn out and defective. But they are super cheap and easy to replace.
Sep 11, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
Lost owners manual, how do I advance the string
Hi don watts46...
Bump the rotating end of the trimmer on the ground while it is running and it will automatically feed the line out, the more you bump the more line feeds out.
Please take time to rate me
Aug 20, 2011 | Troy Garden
I have just bought a Ryobi Expand-it 30cc multi tool 4 stroke. Using it for the first time I filled the oil as instructed, put the petrol in as instructed and then started the machine after 2-3 minutes I...
This may sound like a dumb question, but did you mix the fuel and put it in the machine? If so, you shouldn't have. 4 strokes don't take mixed fuel. You must put the SAE 30 Oil (Not 2 cycle Oil) in a different chamber. Let me know, PLEASE!
Jim
Aug 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
My trimmer only runs about 5 minutes on a fully charged battery, It seems to be overheating. If I let it cool off it will run again, but only for a short time. sometimes grass gets caught around the...
You sure the battery is fully charged. A bad battery will run a bit and then stop providing enough power. Then if you wait it will have "rested" and work another tad. Then rest again.
Almost sure that your battery is bogus.
Sep 22, 2017 | Ryobi 18v P2002 String Trimmer P2102...
Homelite string gas trimmer Model ut20811A: 1. Will start with full choke and run with full choke for a while but will not maintain speed when choke is released. 2. String feed will not feed when taped....
If it only runs with choke on, then mixture is too lean or idle set to low.
Adjust mixture initially at 1.5 turns, then move in or out as needed for highest idle when warm.
Make sure no leaks or clogged filter when adjusting.
Hard to say with string feed, but are you sure you are not putting the spool in backwards?
Mar 12, 2011 | Homelite Garden
How to undo and change the cutting line
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** (bottom) of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a Ryobi BC 30 trimmer. It runs fine but
Are you using the proper size line? Check the ends of the spool. It will give you the size you need. Also while you are checking, locate the arrow that shows the direction to wind the line. Hope this is of some help...Lee
Oct 05, 2009 | Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
252 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
