Question about Dryers
No heat it starts but the igniter doesnt light the gas
The dryer starts but does ignite the gas it stoped suddenly one day
  • 864 Answers
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Posted on Jun 02, 2009
No heat
This information is Courtesy of expert heatman101
If your gas dryer is not working because it is not heating then you need to check this out. Today?s gas dryers often do not use the simple thermocouple with a pilot to prove the flame anymore. They use a much more complicated method of lighting the burner and proving the flame.
The use of electric igniters has become the standard for many dryers today. The thermostat calls for heat, power is supplied to the igniter, then after a certain amperage draw on the igniter, the gas valve is energizes to open and allow gas to flow starting the flame. As long as the amperage draw on the igniter is high enough then the gas valve stays open till the thermostat is satisfied.
Sometimes the igniter will crack and no current will go through and the igniter will not even heat up or glow. Sometimes the igniter will wear to the point where it will still heat up and glow, but the current draw will not be high enough to allow the gas valve to open. This creates a confusing situation where you look into the dryer and see the glow from the igniter, but get no heat because the burner never lights up. If this is the case then you will need to replace the igniter even though it seems to be okay. The only way to know for sure is to know what the current draw requirements are for that gas valve and to have an amp meter to check the current draw.
Nov 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat and a clicking noise when trying to light
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru troubleshooting this. It's a different model but the troubleshooting is the same. You can also enter your model 3 for diagrams and illustrations of your specific model.
May 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool duet dryer doesnt get hot
Is this a GAS Dryer? Or, an ELECTRIC Dryer?
If this is an ELECTRIC dryer, the following link will give you some advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly.
The way the ignition system is supposed to work is like this:
1. Select the dryer cycle and press start.
2. The drum begins to spin and the igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
You can purchase replacement parts (if required) at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 27, 2010 | Dryers
MY WHIRLPOOL DRYER STOPED HEATING THE GAS IS FLOWING BUT THE AIR IS NOT HOT.
The igniter probably needs replacing and is not igniting the gas or it could also be the coils. You will need an authorized gas technician for this repair. Take care and not chances.
Jan 26, 2010 | Whirlpool Dryers
Dryer does not heat up
i take it this is a gas dryer and no you would not usually here the igniter light...good possiblitiy you have a bad ignitor..but you also have a couple of heat sensors on the unit that can also be bad.
Jul 30, 2009 | Estate TGDS840JQ Gas Dryer
Dryer not heating up
Check the following areas to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If all the above check out ok, replace the timer or, control board.
Jun 17, 2009 | Whirlpool Dryers
Kenmore gas dryer model # 87566100
BAD SOLENIODS OR THERMAL SAFETY
Jan 29, 2008 | Kenmore 73952 Gas Dryer
Intermittent ignition
my dryer just stoped. when i press the start button it makes a noise and then theirs a small burnig smell if i turn the tumbler it works for awile then back to the dryer being stoped again.
Dec 09, 2007 | Whirlpool LGR8648 Gas Dryer
Gas burner doesnt ignite somtimes
time to replace your gas coils. those are the two round things on the gas valve. chances are the dryer ignites when first started but as the dryer heats up the coils fail and as it cools again the coils work again. make sure you replace both coils
Sep 19, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
