Question about Westinghouse TX-47F430S 47 in. LCD TV
Screen scrambles into various colors and freezes
Screen scrambles out into various colors and freezes, all picture is lost and it freezes permenantly. I have to pull power and sometimes let the tv sit for hours before it will function properly. TV wont work properly for more than 20-30 minutes. Any thoughts? Anyone have this problem and fix it? What needs to be replaced?
  • 2 more comments
  • sknzfn4lfe Jun 03, 2009
    its hooked up to cable right now but it doesnt matter. Even if i have it hooked up to hdmi input it does the same thing
    it is connected to cable, but even, when not connected to cable, TV does same thing. Also does it if it is hooked only to HDMI input
  • Tony_Lansing May 11, 2010
    Is you TV connected to cable, satelite, or using an antenna?
  • Ginko
    Ginko May 11, 2010
    It is not easy to diagnose for sure the problemMost of the video functions are integrated on the main board:
    http://www.shopjimmy.com/catalog/product...
    The main board hosts the video chipset, and manages all inputs.If it is faulty, the picture can freeze, paricularly if picture it is scrambled , this can be the problem.This part is the first suspect, since it covers most video functions and manages all inputs, however more parts must be tested.
    The LCD controller is the board that send the signal to the display, a faulty LCD controller can cause TV freezing. when LCD controller is bad, it can cause picture freezing.When it is the LCD controller you often get color bands , or color screen, or you just lose raster.
    Here is the part:
    Before replacing parts also the PSU must be tested, even if PSU faults cause shutdown and TV going into protect mode.
    Since some of the parts are expensive (main board $110, LCD controller $49), it is worth giving Westinghouse a call to get a quote on repair, or to locate an authorized repairer.
    To contact US customer service you can call:
    (800) 701-0680
    Regards
  • 10,594 Answers
TV requires main board replacement because problem seems in video processing section.
Main board is available at Shop Jimmy on reasonable price. (click shop jimmy link to see an image of main board)
Posted on Jun 12, 2009
  • Westinghouse Master
  • 19,396 Answers
Parts must be tested to find out the problem. Most of the video functions are integrated on the main board: http://www.shopjimmy.com/catalog/product/view/id/137590/s/main-unit-48-70e01-01a-from-westinghouse-tx-47f430s/ The main board is hosting the video chipset, and also manages all inputs. If this part is faulty, then the picture can freeze, paricularly if picture it is scrambled , this can be the problem.This part is the first suspect, since it covers most video functions and manages all inputs, however more parts must be tested. The LCD controller is the board that send the signal to the display, a faulty LCD controller can cause TV freezing. when LCD controller is bad, it can cause picture freezing.When it is the LCD controller you often get color bands , or color screen, or you just lose raster. Here is the part: http://www.shopjimmy.com/catalog/product/view/id/137533/s/lcd-controller-v420h1-c07-from-westinghouse-tx-47f430s/ Before replacing parts also the PSU must be tested, even if PSU faults cause shutdown and TV going into protect mode. Since some of the parts are expensive (main board $110, LCD controller $49), it is worth giving Westinghouse a call to get a quote on repair, or to locate an authorized repairer. To contact US customer service you can call: (800) 701-0680 Regards
Posted on Jun 13, 2009
  • 3,866 Answers
TV tuner has gone bad and would need to be replaced as the decoder is in the tuner thus both needs a change out. Hopeing this would be under warrenty I do have someone that could provide you a good price for the repair on or off warrenty if you would like.
the url is teexp.com try them.
Rulds2008
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
The Westinghouse TX-47F430S has a lot of problems with hardware and firmware.
I repaired one with a lock up problem.
The mainboard has identifiers W421TA FX69 MB and 48.70E01.01A stamped on it. It is used in both the TX-47F430S and the TX-42F430S. It is made in China, so of course it has capacitor problems. All the caps look normal. There is no swelling or leaking.
C51 seems to be a real problem cap. This is a 470uF 16V located near the U37 sockets (in my photo, it is circled in red). Fortunately I have an ESR meter. This cap measured an amazing 15 ohms. This is way too high. There are also five 220uF 16V caps that had ESR in the range of 0.7 to 1.0 ohms (circled in purple). I believe C51 was the problem, but I replaced all these caps since I had it open. It has fixed the problem. No more lock ups.
I have read of others with bad C51. If you are looking for bad caps on this mainboard, I would start with C51. Be aware that it will probably read good on a regular capacitance meter. You will need an ESR meter to prove the cap is bad.
screen scrambles into various colors and freezes - 40a601e3-8521-4f6f-82de-cd391d382cc1.jpg.
Posted on May 19, 2013
What would be wrong when the picture that went scrambled and the sound remains clear; the screen is full but it just colored lines?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 10, 2015 | Televison & Video
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Sylvania hdtv model lc320sl1 will turn on but does not get picture.... sound works.... various colored lines and or scrambled picture appears at best
Let me start at the beginning---Likely a bad main board in your case but nothing is sure in this type of set.
Main board controls all information to the front screen and communicates to various boards---There really is almost never a simple "that part is bad solution" as any board, the power supply, the main, etc can cause issues.
It can even be a issue with the front screen unit--called a display panel.
You might consider doing some research on the set by Google of the model number with "parts" to get an idea what is available and what potential parts cost might be.
If a main board is bad it will average from one to two hundred just for the part----if issue is the panel you are done--part if even available is more than set cost when new.
Let me know if you have questions.
Jun 03, 2012 | Televison & Video
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
I have an Emerson LC320EM8, the screen scrambled in various colors and freeze
What happens to the sound when the picture freezes? Also are you able to bring up the menu when it freezes?It sounds like a main A/V board issue but I would like to be sure.
Mar 09, 2011 | Emerson LC320EM9 32 in. LCD HDTV
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Scrambled picture and freezing
This is most likely because the GPU which deals with all the graphics on your system overheating, to fix it you need to stop the heat build up.
You can either do this yourself or send it in and get it fixed.
Jan 02, 2010 | Microsoft Xbox 360 Console
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
891 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
