Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Starter overload switch
It looks like the relay switch that plugs into the compressor is burnt. does that mean the compressor is gone or does the relay overload switch has just went out??? Thanks for the advise
  • fickelj Jun 02, 2009
    It has a capacitor, but it is not burnt, should I replace it too
    President:
  • 1,902 Answers
Relay is bad just replace it it is a safety to keep the compressor ok in the event of power surges or failures
Posted on Jun 02, 2009
  • Jeremy Reddick
    Jeremy Reddick Jun 02, 2009
    Yes replace both price is cheap enough
Side by side Kenmore Elite, Mod. 52794100. both sides have stopped coolding/freezing. There is a click, buss, click. Cleaned coils 6 weeks ago. Someone suggested it could be the starter switch?
Is that buzzing/click you hear from the compressor area?
If it is from their, the relay on the compressor has gone out, OR the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload thermostat where the relay is, must be measured, if 17 or higher amps the compressor has locked up, if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Gene
Aug 23, 2011 | Kenmore Refrigerators
L.comTrue model GDM-23 starts and stops(very short cycles10 sec. or so
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 15, 2011 | True 23 cu. ft. Commercial Freezer...
Refrigerator not staying cold..Looks loke it is not turning on.. Is there a switch on the refrigeraor that I can check?
Jan 25, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
Have a GE Profile Arctica that is a few years old. It is "clicking" every couple seconds, like turning off and on constantly. I have been gone for a week if that matters. The HRS light is...
Dec 29, 2010 | GE Profile CustomStyle PSI23SCR Stainless...
The compressor goes to start then cuts out
Dec 29, 2010 | Refrigerators
Fan or compressor is cycling on and off several time every minute.
Dec 22, 2010 | Hotpoint HSM25GFRSA
I have a fridge that i just bought second hand and when i plugged it in the lights came on but not the compressor or any fans. I left i plugged in over night and its still not cold. Is there a kill switch...
If you laid it down when you moved it and didn't wait 24 hours before using it, it's no good now.
Or check the compressor starter/overload relay. It could be burnt on the inside.
Aug 17, 2010 | Frigidaire Refrigerators
Replacement starter relay for skybox MBV1976A...
i lost track of the way the wires go on starter relay. can someone please let me know or send diagram, for the 3 wires. Any help would be appreciated.
Jul 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Jun 29, 2008 | Refrigerators
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
430 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
