Manual missing and I can't figure how to open it to replace paper
I bought my printer prom a friend who has since moved away and I can't find the manual and I can't figure out how to open it tp replace the paper. Talk about elementary questions! Can I download a manual on line or can you just tell me? It's Lazer Printer HL-2140. edka@charter.net
  • 864 Answers
  • 15,935 Answers
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 02, 2009
Ink cartridges Missing or damaged Officejet Pro 8500
Check with another working or new cartridge, if problem not resolved,fault with iss unit(ink supply station). check ISS cables, PCB..replace ISS unit
Jan 31, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error 024-965
Place the designated paper in the relevant tray.
  1. Verify the paper size from the printing application matches the designated printer tray.
    1. Open the application being used to print the document (Example: Microsoft PowerPoint)
    2. Click File and then click Print.
    3. Verify the paper size.
      NOTE: For Microsoft Word and Excel, ensure that the paper size in Page Setup is the same as in the printer driver and the printer.
  2. Make sure the Paper Type is set to AUTO on the Printer.
  3. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  4. Verify that the Actuator No Paper moves smoothly and is not damaged (Figure 1).
    Figure 1: Actuator Location
    • If there is damage or the Actuator does not move smoothly, replace the Feeder Assembly.
    • If there is no damage and the Actuator moves smoothly, replace the Feeder Assembly.
      • If the Feeder Assembly has already been replaced, replace the relevant Tray.
      • If the Tray has already been replaced, replace the Printer.
Abhilash
Sep 20, 2010 | Dell 3100cn Laser Printer
Error 1203
Hi there
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Apr 07, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer will not recognize new blk ink cartridge.
1) Please do not use RE-FILLED cartridges as they will clog the heads terribly.
2) Turn off printer, Remove all cartridges, Gently move the printer head to the RIGHT with short thrusts. It is not necessary to move it completely to the right hand home position just simply away from the obvious jam.
3) With a flashlight and tweezers try to locate paper jam in the print head track. Best to also blow out paper chafe with a weak air bulb. WARNING: Do not let your male friend or relative use extremely strong air pump for tires or air blower at corner gasoline station. (Do not purchase the cheapest paper the future)
4) Unplug the printer to allow it to completely re-initialize the internal electronics..... about 10 minutes should be fine.
5) Replace all cartridges.
6) Power up printer, then re-boot your computer with the activated printer connected, then print a test page. Everything should be fine.
May 17, 2009 | HP PhotoSmart C4280 Laser Printer
Paper jam
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Roger
Jun 03, 2008 | Lexmark T644 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
My printer has gone A-wall
i had the same problem but i finally figured it out
1. open the cover
2. pull the ink cartrage thing to the right while you push the center paper feed button
3. it should move now
Oct 19, 2007 | HP DeskJet 5550 InkJet Printer
71 people viewed this question
jasbo
jasbo
