Question about Dryers
Purchased 12-26-2001. Stopped drying suddenly. Breaker is good. Interior light comes on and off with door switch. Can hear timer run when start is pushed. drum won't turn and no heat. David
  • 1 more comment
  • glass50 Jun 02, 2009
    GE DPR483EAOWW snLA732698W new 12/26/01
    Now what?? I am new to this method
    Are you There?? did I just loose $20 or do I not know how to work with you?
    Brigadier General:
  • 8,619 Answers
Hi David
I understand how frustating it is to face this issue. However please check my answer below for both electric and gas dryer:
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
  • 15,935 Answers
Please use the "continue with this expert" option and reply with the manufacturer and model # so I can be of assistance to you.
Thanks!! :D
Posted on Jun 02, 2009
Washing machine will not start. No lights on panel
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
May 06, 2015 | Washing Machines
Last wash the spin dry never started. Now with any programme selected when I press start button it beeps but nothing happens. Everything else seems as normal - no errors, no any other indications.
Apr 04, 2015 | Electrolux Washing Machines
My machine is just 1 and half yrs old . Its just stopped working . All lights up . Then the start buttom flickers and nothing happens ??
Mar 19, 2015 | Washing Machines
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Amana LEA60AW dryer problem??
Check the door switch to see if it is engaging. This will shut down the motor. I usually do this with a plastic ink pen to see if I hear a clicking.
Feb 03, 2008 | Dryers
Dryers Logo
149 people viewed this question
Top Dryers Experts
