Question about Microsoft Xbox 360 Console
XBOX 360 - E74 WITH ONE RED LIGHT
CAN YOU HELP AND PLEASE DON'T SAY CONTACT MICROSOFT. I get the Red flashing light in the lower right corner (when standing up) ONLY when the AV cable is plugged in. Firing my Xbox360 up without the AV cable is seems to work fine. Is this the sign of a bad AV cable?
  • 51 Answers
Usually when the AV is disconnected all four lights flash red. Cheapest thing to do first is try another AV cord.
However, it's possible that your 360 has been refurbished and the hardware has the chip in a warped position.
If it isn't the AV cable:
You can order a kit for RROD on ebay for about $7.00. Same hardware as what you'd need.
What you have to do is replace the hardware (x clamp) on the video chip the same way it's done when an xbox gets the RROD. reheat the chip so that it connects again by letting it run for about 5-7 minutes with the fan disconnected, turn it off again, wait about 30 seconds and then turn it back on. I fix 360's with this error code at least 3 times a week.
In some cases after doing the clamp trick you will get RROD. No worries, just follow the proccess above and everything will run smoothly.
Posted on Jun 03, 2009
So i take it that 1 red light in the lower right is a huge problem or what?
1 red light in the lower corner is the E74 error.
Sometimes you will not see E74 but it is the display chip that is overheating.
You need to stop the heat build up and you can send it in for repair or you can use a good Xbox 360 Repair Guide.
Apr 13, 2011 | Microsoft Xbox 360 Console
Got on red light,E74
An E74 error is when the lower-right quadrant of the ring piece indicator flashes red and displays an error message in multiple languages: "E74 System Error. Contact Xbox Customer Support". The error is caused when there's a video problem with the Xbox's hardware scaler chip being damaged. As of April 14, 2009, the E74 error is now covered by the three-year extended warranty.
Aug 09, 2009 | Microsoft Xbox 360 Console
One red light on lower right hand corner, e74 message on screen
The G.P.U. is come unsolder from the mother board. Send it to MS
Quick before it does something that's not covered by the warranty.
when you get your newer box back have a good repair shop do
an x clamp mod ,and your xbox problems will be a distant memory.
Trust me I been fixing them for years.
Repairtech
Jul 14, 2009 | Microsoft Xbox 360 Console
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
One red light and E74
You see the lower-right quadrant of the Ring of Light flash red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or display: E74. System Error. Contact Xbox Customer Support.
You will see the following indicator on the front panel of your Xbox 360 console, which will repeatedly flash on and off:
If one red light is flashing and you see a different error message or code than the one listed above, or you don’t see an error message or code, your console may be experiencing a different issue. If this is the case, please refer to the “References/Links” section at the bottom of this article. CAUSE This behavior occurs when the Xbox 360 console experiences a hardware failure.... loadTOCNode(1, 'cause'); This behavior occurs when the Xbox 360 console experiences a hardware failure. THINGS TO TRY Here are some steps that you can use to try to resolve the issue. Turn off the c... loadTOCNode(1, 'whattotry'); Here are some steps that you can use to try to resolve the issue.
  1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
  2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
  3. If you continue to experience this problem, contact Xbox Customer Service.
    Note If the agent cannot help you resolve this issue, you may have to return the console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web Page links: United States customers - Online console repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair) Outside the United States - Online console repair (http://www.xbox.com/support/) Note: Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Mar 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Xbox 360
i order to fix the 3 red lights on your 360 u must take it apart all of it and then clean it from top to bottem and then put back together when the light s flash it does not mean your 360 is broken ight it just means you need to clean it
Oct 31, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 1 red light
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red light Error) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Dec 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
142 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
