Question about Samsung BlackJack II Smartphone
I can hear people but they cannot hear me
When i make or recieve a call on my Black jack 2 i can hear the person on the other line, but i cannot respond to them. in a nut shell i can hear them, but they cannot hear me.
What I did was I took out the battery and the sims card and unscrewed the 4 little screws.... You could have a loose wire or something!!! If this doesn't help Go to AT&T
Posted on Jul 28, 2009
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
I can here the recipiant - they can hear me and we can both see the videos?? Any ideas?
Can you hear anything. iTunes, other sounds? Have you tried different people. There are 2 things I thought of for this problem. 1, the other person is the same person all the time and they have muted their microphone. 2, you cannot hear anything on your system which could be mute, or a driver problem or a problem that can sometimes occur with the headphone jack port. For #1, have the other person try to record something or go to System Preferences and select sound, and make sure the microphone shows gain when they talk, and make sure the microphone is turned up (see picture for this one.) #2 You can try to unmute in the same system preferences, you can also check to make sure your sound system is working in the same preferences. If it is a headphone jack issue, I would plug in and out head phones into the jack until you can hear something (make sure you can hear through the headphones before this, if the headphones give no sound then don't do this.) Other than those items it would have to be a call apple issue. jp_2010_0.jpg
Jun 13, 2011 | Apple Customized 15" MacBook Pro Laptop...
I have a verizon razzle and when i make or recieve calls i cant hear the person on the other line and the person cant hear me. my speaker phone button has also stopped working. Everything else works: i...
i don't have a solution. i have the same problem with my second phone, still under warranty. can't figure it out. first one started working again before i returned it and second one just stopped the other day after a month adn a 1/2
May 18, 2010 | Cell Phones
My motorola razr: I cannot hear the other person on the line when using the hand set, the speaker phone works but otherwise I cannot hear the other person while on the handset
it may be the speaker on the reciever will need to be replaced . This is more common of a fix then you may think . It is a easy fix with out much electrical no how to fix . Just look on line for the part and instructions on line and a way you go on fixing the phone
May 11, 2009 | Motorola Mobility RAZR V3
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Xerox Document Centre 425 DC fax problems
Sounds like a phone line issue.
The phone line isn't a digital line is it? ISDN?
That machine MUST have an analogue line
Mar 27, 2009 | Xerox Document Centre 420 DC Laser Printer
When you call out the person recieving the call hears nothing
As far as I am aware there is note default mute setting so it sounds like the mic is faulty or blocked. They are usually at the bottom of the phone so make sure there is nothing blocking it.
If there is no sound then more than likely, the mic is faulty.
Mar 13, 2009 | Cell Phones
Panasonic KX F511 wont' send or receive
If you cannot send or recieve. First make sure you have a dial tone at the jacj in the wall if you cannot hear it on the handset of the fax plug a phone into it and make sure.
Second make sure you have the line from the wall plugged into the jack on th machine that says LINE. Most machines have three jacks Phone handset and LINE Make sure you are in the LINE jack.
Hope this helps
Feb 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Samsung BlackJack II Smartphone Logo
210 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
