Question about RCA F27242GY 27" TV
Sanyo tv blows fuse when you turn it on
I have a 27" Sanyo tv 7yrs old that when you turn it on, the fuse turns green/blue and pops.  I have replaced it with a 4a/125v fuse and same thing happens again.  Any thoughts or ideas?
Thanks in advance for your time and trouble!!
  • 93 Answers
U have a short in the power supply section
Posted on Oct 24, 2007
Power went out in the house and breaker popped off to where the tv was plugged in. When turned back on the tv won't turn on,The little light indicator turns on for about 10 seconds and then turns off?
Was the TV on a surge protector? If not it likely the main circuit board is shorted out. Contact the local power provider and try submitting a claim for damage.
May 10, 2016 | Sanyo 42 in. LCD TV
Sanyo model # DS32830H, Serial # V3460278431491, Replaced blown fuse, Blew new fuse when turning TV on.
It's faulty to the extent that it's causing repeated fuse blows, so take it back to the store where you bought it, or find a competent service technician
Oct 26, 2013 | Sanyo Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Will not power up, something popped yesterday, and it lost power and will not come on
The fuse might have blown. Could be various reasons. Unplug the TV. Place the TV down on it screen (on a SOFT FLAT, UN OBTRUSIVE surface). Remove the back panel screws and the panel. There will be a fuse, it is likely blown. Replace it with a fuse of the EXACT SAME amperage (it will be stamped on the fuse [example 5A is a 5 amp fuse]). Replace the back panel and carefully tighten all the screws. Replace your TV on it's stand. Plug it in, and turn it on with the remote. If it works, great. If the fuse blows again, you have a more serious problem. Do not attempt to fix it yourself, it could create a fire hazard. Seek a repair shop.
Sep 29, 2009 | Sanyo DP50747 50 in. Plasma TV
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
On/off - fuse blows out
Use a higher amp fuse this should solve your problem if its not a electrical fault in the set.
Mar 09, 2009 | Sanyo DS31520 31" TV
Sanyo HT27547 tv - lightening came in on coax line
Ther is probably a fuse and a diode that got hit by the lighting. If you want to try to fix it yourself unplug it check the fuse and change it if it is bad. Then turn it on again. If it blows that fuse then a diode is also out.
Mar 18, 2008 | Sanyo HT27546 TV
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
RCA F27242GY 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
