Question about Onkyo DX-C390 6-Disc CD Changer
Will not read the disc
Hi
i have an onkyo DXC390 6 disc cd player, and im having troubles
getting it 2 read the discs. I took the cover off and blow sum dust off
the laser area put it back together and it worked.
but ones i opened it a few times putting/taking cds out, it stoped working
and was wondering if u guys had a solution to my problem?
thanks for your time
  • 6,784 Answers
The optical lens assembly is damaged at this point. the lens has burned out and the tracking/load motor seems to be faulty as well. replace the optical lens asap.
Posted on Jun 03, 2009
Compact Disc Player CDP-CX300 not reading discs
Probably have to get the laser replaced as long as all the mechanics are working to load the disc.
Jan 02, 2013 | Sony CDP-CX300 CD Player
Plays 1st disc ok...2nd disc ok has trouble seeing 4-6
Hello,that unit uses one laser and the tray brings each cd to that laser for it to be read.The fact that a particular disc is having problems leads me to believe the disc is at fault,look for scratches and/or fingerprints on its clear metallic side.
Feb 10, 2011 | Onkyo DX-C390 6-Disc CD Changer
We cannot get system to play or read any disc including cd lens cleaner. Have not used for over one year
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Dec 18, 2010 | Onkyo DX-C390 6-Disc CD Changer
CD does not play. I ran a cleaning disc, still does not play
Cleaning discs aren't 100% effective. It's possible the pickup lens is still dirty and not able to read the CD. The best way to clean the lens is by gently swabbing with a cleaning solution designed for cleaning them, but it's not always easy to get clear access to the lens.
The laser may just be too weak now to work reliably. Their power does drop with aging and use. The pickup is replaceable, but part cost and labor may make it just as economical to buy a new player. (I fix these things, and I just bought a new player myself. It was only $20 more than a new pickup would have cost for my old Sony. A seller on eBay had a great deal on new 5-disc Onkyos.)
Also, is this playing any CDs at all? Some older players don't work well, if at all, with burned discs. If you're having trouble playing home-made discs but commercial ones play, this may be why. (It's also a symptom of pickup failure, though, so that may still be the trouble.)
Oct 18, 2010 | Technics SL-PD5 5-Disc CD Changer
Wacs7500 streamium cannot read discs, just says 'no disc' or cannot read disc. have tried a cd lens cleaner with no success
remove the cover and gently clean the lens with a q-tip dipped in rubbing alcohol, then blow the lens dry. if all else fails, replace the optical pickup assembly (lens and spindle motor) or the whole player.
Jan 28, 2010 | Philips Audio Players & Recorders
My onkyo dv-c600 will read DVDs but not CDs
Hi
As per its user manual you cannot play back discs such as VCD (VIDEO CD) ,CD-R, CD-RW, CD-ROM, DVD-RAM, DVD-RW, etc., even though they may be labelled . Please refer to Onkyo DVC600 User Manual for more information.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 25, 2009 | Onkyo DV-C600 Multi-disc DVD Player
Wrong Disc Use Audio CD Problem
Be sure you use the CD-R Audio discs (also known as CD-R Music discs. They are different from the CD-R discs used with computer CD writers, and are a bit more expensive.
Dec 30, 2008 | Onkyo DX-RD511 CD Player
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
ONKYO DV-SP301
the play head of your device known as the ''lens'' is either dirty or bad thats why its selecting disc,try clean it with lens cleaner,if it still does the same thing call your technician,and tell him to change the lens for you.if he does the right thing ,it will work perfectly well.
Dec 13, 2007 | Onkyo DV-SP501 DVD Player
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Onkyo DX-C390 6-Disc CD Changer Logo
581 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
