Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Not firing 20 hp crafstamn turbo cooled not firing help cranked couple times then stoped checked saftey switches ok three wires going to engine black redd and orange redd wire hott with switch off i have a 20hp briggs and straton engine murry mower. i cut it off and now it wont hit a lick. it turns over fine. i sanded fly wheel. if i ground spark plug to metal, it wont fire plug. with a spark tester it shows a spark. i put new plugs in, same thing.i dont know if its the magneto or what. please somebody help. im going to pull fly wheel and check the keyway before i go any farther.
  • 1 more comment
  • patterson355 Jun 03, 2009
    my mower has no coil just a magneto
    duh i was thinking of an auto coil. shows you why i need help.have this part ordered but mine is a dual spark part #394891. thank you rockitman187
  • Anonymous Mar 20, 2014
    Motor want start,try' to but want.
    President:
  • 2,559 Answers
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Posted on Jun 02, 2009
  • Randy Hough
    Randy Hough Jun 03, 2009
    If it doesn't have a coil,That is why it's not firing,All internal combustion engines have some form of coil,Yours looks like the one below.Here is the replacement part # 691060
Enngine does not fire up. no spak at plug
remove the top cover from the engine then the small wire to the coil crank it and check for spark if you have spark with the wire off check your safety switch on the brake/brake pedal it is a dual switch so it can crank and still not fire if there is no spark with the small wire off the coil is bad
Sep 03, 2012 | Poulan Pro 46Inch 22 HP Yard Tractor with...
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
'97 chevy suburban diesel,only cranking but not starting,no security light when ignition is switched on(all other lights come),can hear clicking sound at lhs foot well,fuel pump is pumping but no...
I would start with checking the fuel flow at the filter. Twist open the bleed valve on the top of the filter while you are cranking the engine. If fuel is squirting out, then you are getting fuel past the filter. now you will check the injectors to ensure they are getting fuel. You will need a couple of wrenches to break open the line. You can start with the easies ones to access on the driver's side. Be sure you hold the injector tight while you break the line loose from the top. Just loosen it 1 or 2 turns. Crank the motor and see if you are getting fuel to the injector. If you are getting fuel to the injectors, then we have eliminated a fuel problem.
Are your glow plugs cycling correctly? Every time the 6.5 diesel prepares to start, the glow plugs will cycle. The first time the engine is turned on after it has completely cooled off, they will cycle for 10-20 sec depending on the air temp. That clicking sound bothers me like the relay switch for the glow plugs isn't working. How many miles on truck? Have the glow plugs been changed? Has the relay switched been replaced?
The last area to check will be the air intake system. Pull the air filter housing open and remove the filter. Ensure it is clean and no debris got past it and is obstructing the air to the turbo. (My brother had a filter come apart and plug up the turbo.) Don't buy cheap air filters!
Hope this helps. Let me know if you have any further questions.
I have a 94 K1500 6.5 turbo with 282,456 miles on it. Runs like a champ. Out pulls my new Ford.
Russ
May 10, 2011 | 1995-1997 Chevy Suburban Ignition Starter...
Saw stoped in the middle of a cut, as if i hit the kill switch. checked all of the fuel system, fuel system ok. checked ignition, no fire at the plug, or at the plug wire. i disconnected the kill switch,...
A few checks to do first, remove the spark plug, place it on the top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if ok, remove the muffler and just take a look at the condition of the piston through the exhaust port, any sign of damage, or scuffing and it will need to come apart for further investigation.
Apr 07, 2011 | Poulan 14" Chainsaw
6.0 f250 2005 turns but not start
If it is a standard clutch saftey may be bad if automatic nuetral saftey,
Try auto in nuetral and wiggle shifter while turning key
Apr 28, 2010 | 2005 Ford F 250 Super Duty
I can jump it with a screwdriver and it starts
CHECK YOUR IGNITION SWITCH UNDER STERRING COLUMN LARGE PURPLE WIRE WITH TEST LIGHT SHOULD LIGHT UP WHEN IN THE START POSITION, IF NOT CHECK YOUR WIRING FUSEABLE LINKS NEAR BATTERY? USE TEST LIHGT ON S WIRE AT STARTER WHILE TRYING TO START ? POWER MEANS Bad starter GOOD LUCK
Aug 24, 2009 | 1993 GMC Sierra K3500
85 ranger, engine cranks but won't start. Fuel ok, no spark during crank, sparks at end of crank. 2 weeks ago I replaced the intake manifold gasket and starter, it started right up. The vaccum was at 20...
Sounds more like an electrical problem.First I'd check the battery voltage, should be at least 13. It shouldn't drop much below 11 when you crank the engine and it should bounce back when you stop. Make sure your connections are good especially to the coil,wires aren't frayed or loose on connectors. There should be a ground from the body to the motor. Is it still thereand making good contact? If I'm not mistaken the coil should ground to the motor, make sure it has good contact as well. Also double check your connections at the starter to make sure they are clean and tight. Loose connections can draw extra power and could draw enough extra power to kill the coil. Hope this helps.
Jul 03, 2009 | 1985 Ford Ranger
Not firing
there are a few things that could cause this one it could be that the coil is shorted also it could be a shorted high tension wire better known as plug wire.it could be dirt or rust on the magnetic portion of the flywheel.or it could be the sheer pin that holds the flywheel in place that keyway pin is also the timing pin if the machine hit a rock or for any reason stopped abruptly you could have damaged the keyway pin and threw it out of time simple fix replace pin with a new one.(question )are you sure it is not firing or could it be firing but just weak.?? did you check the key switch i have had some small engines crank but not start do to bad starter switch is it electric start? does it have a oil safety shutoff switch? keep me posted and i will try my best to get you going. good luck and i hope thes tips and questions help mrdmburns@cableone.net
keep me posted..
May 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Switch missing on 10 hp Tecumseh engine that is installed on a
First I have never owned a Tecumseh Tiller. How that got attached to me I don't know. I do have a 10 Hp Tecumseh Engine that I wish to check out if it is good or not before I buy a switch. It has a Brown wire that goes to the low oil shut down sender. It also has a green wire and a black wire. All I need to know is which wires do I need to put together so I can check if the engine is firing or not.
Feb 19, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Engine will not crank intermitantly
Crank sensor can translate heat. Not allowing restart after the turbo heat radiates in the area. Try a wad of aluminum foil in front of the crank sensor(on the block behind the turbo) . It protects it from heat and its a cheep test. If this works you can make a better sheild or leave the foil.
Dec 21, 2008 | 2004 Saab 9-3
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
625 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
