D-Link Router & Actiontec Modem
I am trying to connect a D-link WBR 1310 router up to my Actiontec GT 701C DSL Modem. I have no problem accessing the Internet with just the modem. But once I connect in the router and try installing there's no Internet from the computer side. The modem still shows all green lights. I'm told there is a setting to change for the modem, something about setting to Bridge. I don't see this option if I go into the modems setup.
  • jaded1 Nov 25, 2007
    I have an RCA DCM315R cable modem - I am successfully able to connect to the internet using either USB or ethernet coneections. However, when I attempt to connect my new DLink WBR-1310, I no longer can get internet connectivity. The "PC Link" light no longer lights up. I tried calling DLink support and got so frustrated that I couldn't finish the call. This should not be a hard thing to do!
  • Anonymous Mar 28, 2014
    is a 12v-750mA power adapter ok to use on an Actiontec C1000A modem/router?
/P address 192.168.0.1 same for modem and router. That is problem as to solution, I would love to know how to fix
Posted on Oct 15, 2008
Having the same issue, Something about setting the modem to bridge mode?
Posted on May 09, 2008
I have a d- link modemand when i connect it to the verizon modem a /westell/model 6100.
and then when i connect it to modem and router the green light
that says ethernet doe not ligth up.
please help.
Posted on May 03, 2008
    Problem Solver:
  • 22 Answers
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Posted on Oct 25, 2007
  • Lakshmanan  K
    Lakshmanan K Oct 25, 2007
    Try to reboot your network, if you don't get an IP address in the Status page of your router.
    first disconnect the power to the Dlink Router and Disconnect the power to the modem. wait 1min and plug the power to the modem first and follow the light sequence on the modem ( wait for the lights normal on the modem ) and plug the power to the Dlink router. Make sure internet light or ( it could be WAN light ) on the Router is glowing. ( which indicates the connection between the modem and router )
  • Lakshmanan  K
    Lakshmanan K Nov 27, 2007
    Hi jaded1,
    It sounds like he problem with the ethernet part of the modem. As you said that the USB part working fine. please mak sure ethernet part of the modem also working fine.
    - Connect the computer directly to the modem with the ethernet cable ( modem--->PC ) [ not to use USB ] and check whether you are able to get internet.
    because some modems can support only USB port or else your ISP might disabled the ethernet port on the modem or Ethernet port on the modem might be gone bad.
    - your Dlink router can only access the internet from ethernet port on the modem, then only the computer can get the internet from the Dlink router.
    please feel free to ask, if you need more help on this.
    - Laxman
Hi, I am trying to install D-Link router WBR-1310 but getting the error code 101 IP address not maching. What do you suggest?
Use the PING command to test the communication between the computer and the gateway.
Goto Start > Run and enter COMMAND.
From the Command Prompt, enter PING 192.168.0.1.
The gateway should reply.
Verify that the residential gateway is getting power. With the broadband modem connected to the WAN port on the gateway, you should have a soild WAN link light. You should use the same cable that connected the modem to the PC to connect the modem to the WAN port on the gateway. Any port on the gateway that has a computer connected to it should have the corresponding LAN link light lit. If you do not get the appropriate link lights, try using different cables.
onfigure browser/Internet Options
Step 1 Go to Start > Settings > Control Panel.
Step 2 Double-click the Internet Options icon.
Step 3 On the Security tab click Restore the default security level.
Step 4 Click the Connection tab and set the dial-up option to Never Dial a Connection.
Step 5 Click LAN Settings. Nothing should be checked. If anything is checked, uncheck it. Click OK.
Step 6 Click the Advanced tab and then click Restore these settings to their defaults.
Step 7 Click OK.
Step 1 Turn the Cable/DSL modem off.
Step 2 Turn the D-Link router off.
Step 3 Wait 60 seconds.
Step 4 Turn the cable/DSL modem back on and wait until all the lights are steady.
Step 5 Turn the D-Link router on.
Most routers and modems do not have an on/off switch. Simply unplug the power. Unplugging the power will not reset (reset back to default settings) the unit.
Nov 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Installation problem: D-link wireless router WBR-1310
  1. Push the RESET button on the back.
  2. Plug in the computer only into one of the 4 blue ports (and the router power plug of course).
  3. Give it a minute or two.
  4. Open a browser on your PC, type 192.168.0.1 in the address bar. No www or anything should be there.
  5. You should be able to access the router menu from this address. If this doesn't work, the default address might be listed on the bottom, along with the username and password
  6. If the above steps are successful you should be able to access the internet when you plug in your cable/DSL modem into the WAN port.
From another PC the manual can be downloaded from here:
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip
Hope this helps.
Jul 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I HAVE A DLINK WBR-1310 ROUTER WHERE DOES THE BLUW
Hi!
You can use any UTP cables. Here is how the connection would look like:
DSL -> DLINK WAN PORT
DLINK PORT 1(or any other ports) <---> COMPUTER
If the router is set to give out IP addresses automatically(DHCP), you should be able to connect flawlessly.
Oct 25, 2009 | D-Link 802.11g Wireless Router WBR-1310...
DLink router connected to internet but webpage doesnt open
With an Ethernet cable, connect your computer _directly_ to the cable-modem (or DSL-modem), bypassing the D-LINK router.
Now, can you web-surf?
Sep 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
After connecting router wbr-1310, DSL connection states "limited to no connectivity." What could be causing that problem and how can it be corrected to operate the router?
limited to no connectivity with a wireless system means that it is not picking up the signals from the internet device you have, check if everything is plugged in properly and that your internet connection (modem) has enough strength to be able to be wireless.
Sep 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wii wifi connection
Try to uncheck UPnP Enable on your router located on advaced network setting. or try reconfiguring your wireless network settings.
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
1,926 people viewed this question
Alun Cox
David Payne
David Payne
