Question about SanDisk Sansa Fuze MP3 Player
My Sandish Sanza ( 2gb) backlight screen is black
Yeah, My sansa Backlight screen, the one that makes everything brighter, is not working. The blue light still comes on and the music and movies still play, but i cant see anything for the frist five seconds after i press a button. I have to wait five seconds befor i can see the dimed screen. It's ticking me off because when i want to go to a specific song i have to guess where its at or continuosly press the foward and back buttons
please help
    President:
  • SanDisk Expert
  • 650 Answers
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Posted on Jun 02, 2009
Garmin won't fully backlight so difficult to read
Check your backlight adjustment settings by pressing the power button, this will bring up the backlight settings option where you can scroll it up to make it brighter..
Also adjust the screen timeout
May 30, 2015 | Garmin Dakota 10 Handheld GPS Receiver
Uneven backlight
Your set is probable defective
Sep 21, 2017 | Sansui Televison & Video
I have an Acer Aspire laptop 4810T. It turns on perfectly and everything appears on the screen but it is barely visible. The screen almost appears to be black.
It would seem that backlight for your screen is out. The light may be dead, have a poor connection, or your brightness may be down to zero. To see if the brightness is just low hold the function button "FN" and if you look on the left and right arrow keys there should be a Sun on each one. The left being brighter or filled in, the right darker or hollow. Press the left key while holding the "FN" button. Keep doing this to increase the brightness. If the screen doesn't get brighter there is an issue with the backlight. This is usually covered under warranty. If you still have a warranty contact Acer and they should repair your computer free of charge. If it is not under warranty you may need to replace the screen.
Mar 17, 2011 | Computers & Internet
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
Black screen with high pitch squeel
Hi...there,
YEah...sure! You need to replaced or repaired your backlight inverter....
Oct 11, 2008 | Gateway FPD2275W LCD Monitor
IPod Backlight Broken
I thought my ipod was broken but i did something to make it brighter:
Go to settings and scroll to brightness (i guess it should be right under backlight timer in the menu)
There you will need to scroll clockwise and you will see your screen get brighter.
Anyway I have a ipod video I'm not sure if it's the same as the other ipod series.
Apr 24, 2008 | Apple iPod MA446LL/A MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Backlight wont work?
Check the backlight settings in the menu - yes, cracked screen would definitely cause such a problem
May 30, 2007 | SanDisk Sansa e260 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
102 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
