The installation instructions and the Owner's Manual do not say how to replace the panel. It may not be possible to change without replacing the entire door.
Look for trim near the top of the door that is attached by screws. If the trim can be removed the old panel can be slid up and out and the new panel can be slid in. Alternatively look for side trim piece(s) that might be removable allowing the panel to be slid in.
yesterday the dishwasher sounded like it was shorting out at the end of the drying cycle. it sounded...
(More)
yesterday the dishwasher sounded like it was shorting out at the end of the drying cycle. it sounded like it was going on and off with 2 minutes showing on the display. this morning it appeared to work fine. now it will not start at all. any idea why?
the three second light goes on every time you push a button for a particular cycle, But after the...
(More)
the three second light goes on every time you push a button for a particular cycle, But after the light goes out the disher still doesn't. I know about the three second lock but that procedure doesn't allow the cycle to run when the three second "unlocks" I checked main fuse in house. But since the three second light goes on I don't believe I have a power problem, One time I pushed the three second button and a button cycle and it worked. However this technique do not solve the problem because when I tried that again the dishwasher cycles did not work.
My diswasher came with my new home about 5 years ago. It's started to make a very strange grinding...
(More)
My diswasher came with my new home about 5 years ago. It's started to make a very strange grinding type of sound
