Question about Anti-theft Alarm System 3 Series E90 E92 Bnib
BMW ANTI THEFT SYSTEM WILL NOT DISARM
I have a 2001 bmw 330i. I unlocked the car with the remote key and the car will not start. The dash lights come on and the headlights flash on but the engine will not turn over. Someone told me that that meant the alarm system was not disengaging. If that is so How do I get it to disengage. 2002 BMW 325ix wagon. Anti-theft system will not disarm. When I try to start the car: Hazard lights flash. Headlights flash from high to low beam. Instrument panel lights flash. It began with static when playing my CD player. I shut off the car and then tried to restart when the problem arose. How can I reset the anti-theft system?
  • 124 Answers
OPEN THE DOORS AND BOOT LID AND TURN ON THE IGNITION THEN YOU DISCONNECT THE BATTERY FOR 11 MIN AND RECONNECT ON THE OBC A TIMER WILL START WITH THE ALARM SOUND AT THIS TIME DO NOT DO ANY TIME OR OPEN OR CLOSE ANY DOORS.WHEN THE TIMER HAS COMPLETED 15 MIN IS THENORM THEN ONLY DO YOU STAR UP BUT DO NOT TURN THE KEY BACK WHEN STARTING THIS WILL JUST RESET EVERYTHING.
Posted on Jul 24, 2009
3 Suggested Answers
SOURCE: BMW 330i 2003 model... Recently, the alarm has
BMW 320d sport touring 2003 alarm goes of intermitatley/ hazards don't work some times when setting the alarm with remote
If you open and close the bonnet alarm sets but after a while the alarm goes off again.
Fault traced to bonnet switch found just in front of brake fluid reservoir. switch bracket broken. Remove switch from bracket
Supper glue bracket and clean switch with electrolube switch cleaner. it worked for me. Hope this is of help. Neil
Posted on May 27, 2010
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
2007 328 XI. Key fob in B Yellow key appears on dash all dash lights come on but why won't car start?
car is in lockdown because the antitheft system is sensing a fault. see owners manual. usually you have to exit the car lock it with the remote and unlock with the remote and turn key to run position and observe the lights on the readout for security and retry starting car
Jun 22, 2015 | BMW Cars & Trucks
2001 bmw 330i lock
change your central locking relay.
Jan 17, 2014 | BMW 330 Cars & Trucks
Battery light wash flashing.car then died while driving
More than likely it is the alternator not putting out enough to run the car.
May 22, 2013 | BMW X3 Series Cars & Trucks
I have a bmw 330i and the doors will not lock using key, i have replaced the key but it didnt solve the problem... what needs to be replaced?
if the door locks work manually with using the key in the door then probably will need to just reprogram/initialize the key especially if its a new key. if the power door locks dont work at all using the key manually then first check the fuse.
initializing key:
all these steps must be completed within 15 sec. of cycling the key i.e. turning the key off
step 1: get in vehicle close all doors and trunk
step 2: turn ignition on tell all dash lights are on but engine is not started
step 3: turn ignition off pull key out
step 4: press and hold the unlock botton down while then at the same time press the lock button three times in a row
step 5: door locks should initializ at this point they will lock and unlock on there own to show process is completed
Mar 04, 2011 | 2003 BMW 330
Remote locking
Is it the old style key? if so does the red light flash on it when you press the unlock/lock buttons?
does the red on the dash or under the rear view mirror flash?
Sep 18, 2010 | 2001 BMW 5 Series
2001 330i BMW hazard lights & central locking in car won't work
I'm having the same problem have you fixed yours?
Jul 11, 2010 | 2001 BMW 330
2001 BMW 330i wont start. Immobolizer?
Sounds like a dead battery or a dead starter. Try using a jump box or jump start first.
Feb 27, 2010 | Anti-theft Alarm System 3 Series E90 E92...
the easiest way to fix this problem is to remove all wires for the alarm as alarms always cause more problmes than they actually protect. You must locate the alarm computer it can be anywhere underneath your dash under the seat in the engine bay it will say alarm or the brand on it locate it and un clip than your done or have it serviced so that they will cut the wire also called the kill switch to your alarm it will still function but this pesky problem will go away
May 26, 2009 | Anti-theft Alarm System 3 Series E90 E92...
2001 bmw 330i
The starter solenoid is defective, the contact inside the solenoid that energize the starter are burned, remove them and look bet they are heavily pitted, replace the starter.
Dec 01, 2017 | 2001 BMW 3 Series
Keyless entry keylob want lock or unlock doors or trunk.change battery and checked all fuses.
You need to program the remote. Get in to the car and LOCK all doors with the switch on drivers side door. Take the key and insert it into the ignition cylinder in and out 6-10 times, until the flashers/hazards flash on your dash board. Or just keep putting the key in and out (nice and easy now, not fast) until you see the lights on dash flash. After the lights flash, turn the key into ACC mode to make the whole dash light up.(do not start car) .With the key in ACC position, hit any button on remote, that will make the hazards flash again. Turn key off and unlock door with switch again. Open door.DONE.
Good luck.
Jul 15, 2008 | 2001 Nissan Altima
Anti-theft Alarm System 3 Series E90 E92 Bnib Logo
4,705 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
