Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
2 diodes bad ,in spots D413 and D414. I need part numbers for them and possibly the whole service manual
The diodes are bad but i do not have the part number of them
    New Friend:
  • 13 Answers
Call andrews electronics in california 18002890300 and you HAVE TO OPEN AN ACCOUNT. chances are (and i just replaced a bunch of parts on the mw27f51) you have more bad parts if your vertical circuit is burned out. I found i had to replace ic 401 and d413 and d408 and d414 and puffy c402 and c421 and c427. If you give the model number to andrews they can look up part numbers from these location numbers.
Posted on Jun 23, 2009
My whole screen has white spots
Hello, what is the model number of your set? If it's a DLP set it's very possible that the chip in the "light engine" has gone bad....tks
Nov 08, 2013 | Televison & Video
LG 32lh200 power supply failure common problem
You might try to follow the diode back to the source and read voltage to know the value of the diode and also look on the diode for generic number--short of that Google the model number with "parts" as it might be cheaper to replace the board than try to fix it by guessing values.
Aug 27, 2012 | LG 32LH200C-A1 LCDTV 32LH200C 32inch Wide...
Re: GE Microwave Oven #JVM1870SF001...turns on but will not heat-up item. Can it be the Magnetron and/or Diode is bad?
More than likely it's the magnetron and/or diode, chances are it may still be under warranty. Online owners manual states 5 year warranty on magnetron. Part only, service call and installation not included. Diode not covered. They require serial number, and will let you know if it's still under warranty. Installation appears to be simple, UNPLUG MICROWAVE THEN MAKE SURE YOU DISCHARGE CAPACITOR. INJURY OR POSSIBLE DEATH IF NOT DISCHARGED PROPERLY. Google how to install magnetron and discharge capacitor. It will save you approx $ 250 - 300 doing it yourself. Hope this helps. Be Safe
Dec 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heat from my JVM1640CJ GE microwave. Fan, lights work fine. Unit is less than 5 years old.....I've read some posts on this site - could it be a bad door switch? chip
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Pop smoke and blurred screen. Found burn spot on botom of PC board under what appears to be the high voltage power supply. Looks like a charcoaled capacitor and maybe a diode. Have not tested the diode...
jdowell1,
The easiest solution would be to go to http://www.servicemanuals.net and purchase a downloadable service manual for about $16 US. If you plan on working on this unit in the future it should more than pay for itself. The manual would have the values of the components and much more valuble information.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 05, 2010 | Samsung HCN4727W 47" Rear Projection...
Omniquest Q9B monitor, Diode Identification
You need to get a service manual, this has all servicing information, including, the schematic diagram too, this will have values, for all components.
It could be a Zener, of almost any voltage, within a range, or a shottkey diode, a signal diode, or a flywheel diode.
Apr 07, 2010 | Computers & Internet
No Power - DOA
Mike,
If there are burn spots on the power board, then it is shot. Go to www.eserviceinfo.com to get a manual, most likely they'll have one there. I service all makes and models of printers, faxes and copiers, they usually have what I am looking for.
David
Protech Printer Solutions
Apr 17, 2009 | Samsung SCX-5115 Fax Machines
Vacuum faulty power PCB, Need service manual/schematic
No schematic found. The Q1 transistor is a 2N3904, D3 was replaced with a 1N4000 series.
Root cause still Unknown, but Q1 is an exact match and D3 is an acceptible replacement.
Hoovers solution is to replace the whole PCB no matter whats wrong with it, what a waste or good technology!
Mar 30, 2009 | Hoover Self-Propelled WindTunnel Bagless...
61 inch Ultravision Digital tv,no sound when I turn it on
check for defective IC401 audio amp
also check d409 d410 d414 d413 for short
and check electroletic caps in audio amp
Jan 14, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Your assistance
The Sony part number for these diodes is 8-719-108-12 and yes they are 9.1 volt zener diodes @ 1 watt. I have the service manual for this set if you need it put can only send a large file like this trough a proggy called pand, so if you go to pando.com and get the proggy and leave youe e-mail addy I will send you a copy of this service manual. Good Luck
Mar 26, 2007 | Sony KV-27S65 27" TV
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
233 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
