Question about Toshiba Portege M400-S4032 Notebook
Changing the drive letter
I was given a Portege M400 to wipe clean and put on a new OS.  Usally this is a piece of cake.  Well this one is not.  when i go to put a clean copy of an OS it says that there is is no drive installed in the machine.  Now when I use Vista it shows a drive by the letter of X, and it is unaccessable.  It also says there is is no drive and/or the drivers for the drive need to be installed.  Locating the drivers seems impossible.  Is there a back door way to change the drive letter? Or?
Thank you
confused
    Scholar:
  • 90 Answers
If im not mistaken, you need a RAID driver for this model. I don't recall, but does this thing have a floppy drive built in? Or do you happen to have an external? You might be able to use the cdrom to complete this, never tried this way, in the event you dont have a floppy drive.
Visit this page - http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1363702&rpn=PPM41U&ct=DL&BV_SessionID=@@@@0308016801.1193190290@@@@&BV_EngineID=ccchaddmflilldicgfkceghdgngdgmm.0
Download the RAID driver relevant to the OS your going to install. Let's say for XP. After downloading, extract the files in the archive. You will find a folder named Drivers. The files in that folder, need to go on a floppy disk. If you dont have a floppy disk, you may need to make a trip to your local computer store and pick up a USB Floppy drive.
Insert the XP install cd. When the screen turns blue you'll see an instruction to load a third party driver at the bottom of the screen. It says to hit F6. So once the screen turns blue, tap the F6 a few times.... XP will eventually ask you for a driver disk, at this point, you insert the floppy disk into the floppy drive. And hit S in order to specify additional devices.
The rest is pretty easy from there. You should be able to continue on and install windows.
The reason it doesn't see the drive, is because Windows does not recognize the Raid controller that the drive is connected too. Thus, you need to load the driver for it from the F6 funtion during the OS setup. Have questions, let me know.
Posted on Oct 24, 2007
Bootmgr missing
You need to re install OS.
There is a built in OS in your hard drives hidden partition.
Turn on your laptop and hold down '0' while rebooting.
That is holding down the number zero. Then the steps on how to reinstall OS will appear
Oct 10, 2013 | Toshiba Portege M400 Notebook
I am using a toshiba portege m400 and try to upgrade harddisk to 250 gb while installiing windows 7 hard disk is not detected.
maybe its not compatible to the laptop the hard disk that you purchase try replacing it with lower capacity hard drive then reinstall the windows 7 again
Aug 07, 2011 | SIB 250GB 2.5" SATA HDD Hard Disk Drive...
Keyboard on toshiba protege m400 not working
hi this could be several reasons for not working firstly it could have been liquid damaged /spillage etc check keys are they sticking when pressed if so you will need to remove panel and remove keypad and clean the unit iff this fails check lead at base of keypad entering the board this might have come lose or even broken away .you might even try changing the keypad if all fails hope this helps you
Mar 12, 2011 | Toshiba Portege M400-S5032 Tablet PC
How/where do I insert the SIM card? Thanks in advance
It is on the right hand side of the laptop above the dvd drive. There will most likely be a blank piece of plastic that protects the opening, if you press on this blank it will release and can be pulled out of the way, this blank and the memory card only fit one way and when you put the card in, it will click in place and lock, to unlock simply push in on the card and will unlock and can be pulled out. Below is the service manual, look on page 249, chapter 4.3.2
http://tim.id.au/laptops/toshiba/portege%20m400.pdf
Oct 03, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba m400 builtin hard is offline
Did you look at the BIOS setting? Try hitting Esc then F1
Jan 27, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
How enter to bois
Fadeel, You enter the BIOS on the M400 by pressing the ESC key during the POST operation. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 23, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege M400-S4032 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
