Question about Dell Inspiron 6400 Notebook
Monitor will sometimes refuse to turn on
At power up or restart, more then often enough, the laptop monitor will refuse to turn on. However, it will come back to life now and then. I can assure you that the problem is neither the Inverter PCB or the backlight/LCD itself. How do I know this, because I've already changed both and the problem is still there. The video cable, also, can not be the problem because the monitor will sometimes turn on, usually by having to press F8 together with the power button, or having to remove the battery or the AC power, one or the other, and then the Laptop monitor works fine with no problems. Until I re-start or reboot the laptop and ther we go again. Yes, an external monitor proves that the video PCB is good, but can there be a part of the Video Circuit that works seperately with the laptop then with the external monitor ? One things for certain, I have not found the solution yet.
  • Barry Parks May 11, 2010
    Have you tried the Fn + F8 key combination to toggle the video mode? The Fn key is in the lower left of the keyboard. This key combination will toggle from the build in display, a remote monitor or projector or both internal and external. It may be that the system is coming up in a state that is only sending the signal to an external device.
    Another question, is the Dell splash screen displayed and then does the screen go black when Windows is loading?
    I hope this is helpful. Please let me know.
    ~ Spoem
  • 197 Answers
Try to update your video driver. If you already tried to check on the external monitor and no problem then it's your LCD video or mother board is faulty. If you updated the video driver and still the same problem then it's your motherboard that needs to be replace.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jun 05, 2009
My j5 create VGA adapter will not connect
So the major limitation on today's computers is the Max power available to the USB bus on the motherboard. Last I checked this was 1,000 mA. This unit draws 500 mA. Depending on how many other things are connected via USB to the laptop, youmay not have enough power to drive the dongle. Best solution for this, even if it isn't the problem, is to get a powered USB hub. That relieves the need for the OS to do calculations on which devices get USB power at start up.
Try this if you can.
Mar 05, 2014 | J5 Create USB 2.0 VGA Display Adapter...
There is a power supply going through the laptop....but the fan refuses to work. and monitor does not turn on.
Then the motherboard is dead most likely. If you have no power to the fan or monitor that would be my guess. You should try checking the output voltage on the charger make sure its good with a volt meter.
Aug 16, 2010 | HP Compaq Presario 2200 Notebook
Polyview V17E monitor looses power at irregular times
Check your power saver settings
Start - Control Panel - Power
May 08, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Computer not recognizing video card maybe?
If you have a onboard graphics on your mobo they may have been turned on somehow I would check there and disable them if they have been.
Aug 15, 2009 | ASUS Extreme AX800XL Radeon X800XL, (256...
I have LCD Benq 17" monitor that suddenly refuses to power up!
that shouldn't have messed up your monitor at all. It sound slike it needs to be reset. Unplug the monitor for at least 5 minutes. Then plug it in and power it back on.It may be stuck in a standby mode.
Jun 03, 2009 | BenQ FP731 17" LCD Monitor
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Wont Turn on, Monitor Flashes a bit
oops, I did see the model on your Presario.
This sounds like it could be the motherboard or power circuitry.
If the DC jack was replaced, and the AC adapter, I would say the motheboard is bad. I have seen this on many models, not just the Hps.
If your laptop is under warranty, I would definately contact HP. If you have a local repair shop, that is probably your next best bet.
Mar 26, 2009 | HP Compaq Presario C502US Notebook
Monitor
Sounds like you may have a bug, you could try re-ionstalling everything fresh, it may need a driver update. Check the funtcion keys. Sometimes you can turn up the screen contrast by holding the function key and hiiting the function key that looks like a white and black sun, Black is for darkewer, white is for brighter.
Also, ost laptops when on battery power, will auto dim to save battery power.
Feb 27, 2008 | Dell Latitude C640 Notebook
Sony GDM-F500R (G1 Chassis) has trouble turning on
sometimes relay contacts get "sticky" from arc oxide corrosion whenever enough electricity is passed from metal to metal...in a perfect mechanical relay, the relay would be sealed in a vacuum. Try swapping relays to transfer the problem. If you can transfer it, you found the bad relay. I actually have disassembled relays and polished their contacts with great success.
Nov 13, 2007 | Sony GDM F500R Monitor
Dell Inspiron 6400 Notebook Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
