Question about NEC ETW 16DC-1 Corded Phone
Programming We have Level I Electra Pro phones in our office. The operators phone is the only one that rings. Is there any way to program my phone to ring when a specific line has an incomming call? I appreciate it !!
  • 149 Answers
Yes enter program mode and change MB 4-01 for your port number. Assignment of ringing per phone.
Posted on Jun 14, 2009
Our office has a two line system on a idcs 18d our first line will ring throughout the office but the second line is silent and only lights up. How do we make it to where it rings as well?
Assuming you have the programming manual, you need to program trunk 702 to ring to the operator group 500 in MMC 406 in the software programming manual.
Feb 29, 2016 | Samsung Falcon iDCS 18D Display Phone with...
NEC LEVEL II PHONE THAT WILL NOT RING
Ringing is assigned in system programming, usually done by the service company unless you have a phone tech or IT guy/gal who handles this.
Jul 07, 2014 | NEC Electra Professional ETW-16DC-2
I want to replace this phone. What is compatible for NEC Electra
It doesn't exactly work that way, but I'm guessing that you have 8 button terminals. You can replace them with phones like this: http://www.pcliquidations.com/item.asp?id=1678
There may be some programming required to make them work.
Carl
May 04, 2010 | NEC Electra Professional ETW-16DC-2
How do you turn the ringer off of an NEC-DTU-32D-2?
you need to remove ringing programming in 4-01 for that extension. ldtsnj.com
Feb 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Jan 20, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Jan 06, 2009 | NEC Electra Professional ETW-16DC-2
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Dec 16, 2008 | NEC Electra Professional ETW-16DC-2
"NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
Dec 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite
you need to access program mode. Did you contact your nec vendor? ldtsnj.com
Apr 24, 2008 | NEC Electra Elite 32D-1 Corded Phone
LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
Jan 28, 2008 | NEC Electra Professional ETW-16DC-2
NEC ETW 16DC-1 Corded Phone Logo
131 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
