Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Mower will not drive
I have 15.5 hp 38" cut poulan and when i release clutch mower dies or when i engage blades mower dies. whats the fix?
  • 376 Answers
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Posted on Jun 03, 2009
I have a poulan 38" mower. Something seems to be wrong with the deck. The left side cuts great, but not the right. The right side seems to beat the grass into submission. If I back up over the same path I...
check mower blades for blade upside down. you may be hitting grass with back of blade. match blade position to working blade side. or swap blades left to right and see if problem moves. if so, blade is culprit. also cold be a loose blade bolt allowing the shaft to spin without driving the blade. Do all work with engine off key out!
May 16, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My 15.5 briggs and stratton cuts off when i release the clutch or try to engage the blades.It did it last week and i changed the fuse and it run fine,i tried another fuse and it didnt help.any advice?
There is a seat safety switch located beneath most seats, and on some models one on the PTO lever. Depending on the model, there will also be one on the foward reverse tranmission lever if equipped.
Apr 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My Poulan 13.5 hp runs until cluch is released
remove the drive belts from the motor. if it runs ok check your pulleys. one of them might be siezed.if it still dies chk the safety switch on the gear selecter and deck engage lever.
Sep 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Jul 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engage blades makes noises
Sounds like the bearings are going out in one or both of your blade spindles. With the belt off,(and engine, of course) engage the lever on the dash. That will release the blade brake so the blades will be free to turn. Spin each one by hand. It will be easy to tell if the bearings are bad.
Jun 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
433 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
