Question about Maytag MEW5527D Electric Single Oven
Oven will not turn from top panel electric panel is stuck on 5a6
Oven will not turn on from top panel electric panel is stuck on 5 a6
  • 6,784 Answers
Unplug this unit for 3 minutes. if the control fault still exists after the 3 minute reset, replace the affected control board.
Posted on Jun 03, 2009
Hi. When you turn on the top oven the upper element doesn't shut off after it gets to the set temp.
It could be a stuck or welded relay in the control board. Sometimes a sharp rap on the relays on the control board will jar the contacts loose. Be careful not to tap too hard and make sure the power is off. If this doesn't solve the problem you may have to replace the control board.
Mar 28, 2014 | Maytag MEW6630DDB Electric 30 in Double...
F-24 goes on after oven on, and oven starts to beep
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Feb 28, 2011 | Thermador C302U Electric Double Oven
Hi, I have the Jenn Air model SVE47100 and it seems I have a short. My oven is turned off by means of turning off only through the electrical panel. I can not seem to turn it off. If it gets electricity,...
Sounds like the broil relay on your ERC (electronic range control) / clock is stuck. Until it's replaced the only way to keep it off would be to cut power to the range.
Jan 18, 2011 | Jenn-Air Ovens
The door to my viking oven is locked and stuck, does anyone know how to unlock it?
Must be taken out of wall far enough to remove top panel and manually disengage lock
Nov 20, 2010 | Viking 27" Professional Select Built-in...
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Oven Door Locked After Cleaning
Go to electric panel. Turn off the oven breaker, open door, now turn breaker back on.
Jan 16, 2009 | Ovens
Kenmore double-oven (electric)
F7 stuck keypad
Sep 22, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
Maytag MEW5527D Electric Single Oven Logo
243 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
