Question about GE GSS25JEMWW Side by Side
Loose refrigerator door handle
My GE refrigerator # GSS25QGTACC is about 2 yrs old and the door handle be came loose. There is one cap on top and one cap on the bottom of the handle but I don't know how to remove them so I can tighten the the screw or whatever kind of fastener is under the caps.
  • Anonymous Mar 13, 2014
    WHIRLPOOL GOAL 3 door refrigerator / freezer, door handle on bottom freezer door is loose, how can you tighten the handle
  • Anonymous Mar 20, 2014
    how to tighten door on GE refrigerator LSHF6LGZBCBB
  • 833 Answers
Weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE:
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How do I repair of loose door handle on rerigerator ge model 20?
I believe the door handle slides up after you get the screw out
Mar 02, 2018 | Refrigerators
My GE counter top microwave will only count down. The light, fan, and turntable will not work. Lifting the door solution did not work. It's only 2 yrs. old.
I would suspect a door switch is defective or its mount is loose, misaligned, or broken.
See my he;p file on door switches here.
Dec 27, 2013 | GE Microwave Ovens
Need to tighten loose door handle on refrigerator side
Hi, Look at the top and bottom end of the handle to see if there is a cap that can be removed. You should find a screw behind the cap to tighten. \Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Mar 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Nov 07, 2008 | GE Refrigerators
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
GE GSS25JEMWW Side by Side Logo
242 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
