i have a problem with my dvd player! i accidentally put it on progressive scan and now, no images can be seen how can i get it back to the interlaced mode??? need answers asap ty! my dvd player is a pioneer dv 393 si have a problem with my dvd player! i accidentally put it on progressive scan and now, no images can be seen how can i get it back to the interlaced mode??? need answers asap ty! my dvd player is a pioneer dv 393 s
My dvd player is on progressive scan and i cannot get it off. Its a Zenith home theater system.My dvd player is on progressive scan and i cannot get it off. Its a Zenith home theater system.
i have a problem with my dvd player! i accidentally put it on progressive scan and now, no images can be seen how can i get it back to the interlaced mode?I Don't Have a remote for it either where could i get one Nexxtech esdvd100
You can't post conmments that contain an email address.
In order to use progressive scan you must have a progressive scan compatible tv. Check your users manual to find out if its compatible. If it is it should give instructions to turn on the progressive scan option for tv.
This is probably the 'progressive scan' feature for your DVD player.
If you haven't had any other problems with the player, try pushing the button again (a second time). This feature is likely a 'toggle-on, toggle-off, so a second 'push' should turn-off the progressive scan.
If this doesn't correct it, power the unit off, then power-on again. It it doesn't automatically power-up without the progressive scan, try pushing the pscan button again. Hopefully this will turn-off your undesired progressive scan. Good luck!
Sorry but this DVD does not have progressive scan. Before buying another DVD player with progressive scan ensure the tv you have can receive progressive scan signals. If not it doesn't matter if the dvd has progressive scan or not. Hope this helps.
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
i have a problem with the progressive scan mode on my dvd i can turn off this mode
