Question about Panasonic PT-56DLX75 56" HDTV
Panasonic DLP PT-56DLX75--Flashes orange 6 times, pixelated darks
Panasonic DLP PT-56DLX75--Authorized service tech replaced entire assembly in back. Said lamp was still ok. Now even after this service, power indicator lamp flashes orange 6 times after TV on for about an hour. When picture is on, shadows of faces and dark walls look pixelated. Picture not as good as before problems surfaced. Thanks for your help I have the same issue on a Panasonic PT-56DLX75. Works great for about an hour then shuts off and displays a yellow/orange flashing light at the power button. I can unplug it and get it to come back on, but a few minutes later the problem returns. I've tried cleaning it out and making sure it wasn't a heat issue but with no change.
4 Suggested Answers
  • 4234 Answers
SOURCE: How do I rest the lamp times on my DLP TV Panasonic PT-56DLX75/PT
The reset procedure is usually documented in the owner's manual. But if you can not locate that, please update this with the model number of hte set and we'll get that info for you. Please note that the procedure is relatively simple, but dependent upon the model number.
Thanks,
Dan
Posted on Feb 05, 2009
  • 125 Answers
SOURCE: PT-56DLX75 turns off red light flashes. Replaced
You need to first CK power supply board for Bad capacitors they will be vented,swollen or puffed up on top ,if you do not see any then try replacing Ballast Board it is what Powers Lamp. Call Encompas Parts Dustrubtion for Part numbers and Prices or Visit teir Website online!
Posted on Mar 24, 2010
Testimonial: "good help "
hardrocko
  • 1476 Answers
SOURCE: Ineed to reset the lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Oct 28, 2010
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Where do I purchase and how do I replace a picture lamp for a panasonic PT-56DLX75 56 in. HDTV Television ? I live near Sioux Falls, South Dakota.
Hi there this online store has the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=PT-56DLX75
this link has your TV manual and check page 67 it will show you were the lamp is located in your TV
http://service.us.panasonic.com/OPERMANPDF/PT56DLX25.PDF
this link shows you how to replace the lamp
http://www.fixyourdlp.com/guides/panasonic/TY-LA2005.php
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 11, 2010 | Panasonic PT-56DLX75 56" HDTV
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
Mar 24, 2010 | Panasonic PT-56DLX75 56" HDTV
How do I reset the lamp timer on my panasonic dlp tv?
Most Panasonic lamp driven TV's use either the PIP or SPLIT button on the remote control pressed simultaneously with the VOLUME down on the TV. These two buttons must be held in that position for more than 6 seconds then a box should appear on the screen letting you know the timer was reset to zero. The instructions usually come with the lamp as they are not in the owners manual. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Panasonic PT-56DLX75 56" HDTV
Thanks,
Dan
Feb 05, 2009 | Panasonic Televison & Video
Panasonic pt 52lcx66 won't turn on
Sounds like the light engine. Is this a DLP or LCD rear projection? Did you see any patches of color any time before the problem with the really dark screen. Please rate my answer and let me know what other questions, Tech Malick
Jan 31, 2009 | Panasonic PT-52LCX66 Projection Television
56 inch rca hdtv
Good Day;
The RCA TV uses a different type of Convergence Circuit then most other TV's. There is A fuse next to the FLY BACK that opens that can cause this. If not handy call an Authorized Service Center, get an estimate. Cost avg $400.00 to $650.00 depending on your location and problem.
Good Luck, big IRISH.
Sep 22, 2008 | Panasonic PT-56DLX75 56" HDTV
TV Turns off
you can get the service manual at the following link for youe model DLP and they provide free tech support to help you diagnose your set.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-56DLX75 56" HDTV Logo
319 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
