Question about Airtemp Heating & Cooling
Need electrical diagram
I need the electrical diagram for an AirTemp model C2T18F7Al, serial ED498157 1472 or the directions for reconnecting the electrical leads to the switc selector.
  • red769 Jun 02, 2009
    i need either the diagram or directions to reconnecting the electricl leead to the switch selector
  • 3,741 Answers
C:\Documents and Settings\Administrator\My Documents\Downloads\papu.gif
or
file:///C:/Documents%20and%20Settings/Administrator/My%20Documents/Downloads/papu.gif
thanks.keep updated.
Posted on Jun 02, 2009
    Novelist:
  • 130 Answers
Comprising power supply wiring; a heating-cooling thermostat energized by the power supply wiring; a heat producer electrically wired to the heating portion of the thermostat for heating the furnace air when the thermostat senses a demand for heat; a fan for moving air through the furnace; an air cooler electrically wired to the cooling portion of the thermostat for cooling the furnace air when the thermostat senses a demand for cooling; and an air-temperature-responsive switch wired to the fan for energizing same when the air is heated to a predetermined temperature: the improvement comprising a fan energizer relay having a control winding wired to the cooling portion of the thermostat for energization when the thermostat senses a demand for cooling, and winding-controlled switch means wired to the fan in parallel with the aforementioned air-temperature-responsive switch, whereby the fan is controlled by the air-temperature-responsive switch during the heating season and by the relay during the cooling season; a furnace junction box operably receiving therewithin the power supply wiring, the air-temperature-responsive switch wiring, the relay wiring, and the fan wiring; a plug-on connector board carried on the junction box for operably mounting the fan energizer relay; said connector board having individual electrical connector surfaces exposed to the junction box interior and exterior, and the junction box interior wiring having terminal ends attached directly to selected ones of said connector surfaces; the aforementioned relay having rigid terminals for its winding and its switch means; said relay terminals being spaced from one another in accordance with the spacing of the board connector surfaces, whereby the relay can be plugged onto the board so that the relay terminals electrically connect with selected ones of the connector surfaces.
click this link for wiring  http://www.planethoustonamx.com/main/AMX_Javelin_AC_wiring.jpg
thanks.please do rate the solution.thank you for using fixya.keep updated.
Looking for btu on airtemp imperial ll model
This information can usually be found on a small plate welded or glued onto the side/rear of your A/C units along with the model & serial #s. Although it would be a highly illogical place to put this plate, you may also want to check the bottom but if you turn the unit upside down, do not turn it on for 24 hours, as the gas & oils will be displaced & you can kill off the compressor by doing so.
Jun 15, 2009 | Airtemp B3Q06F2A Air Conditioner
Through the wall airtemp air conditioner
If the compressor is running, you have a freon leak. If the compressor is not running, you have an electrical problem, unless the compressor itself is bad.
Jul 26, 2008 | Airtemp Heating & Cooling
Fan relay wireing
It is a peanut style relay with 5 wires. Two which are for a coil, and 1 normally open and one normally closed and one hot. The relay on that model does tell you that.
Oct 18, 2007 | Airtemp B6D30E7A Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Airtemp Heating & Cooling Experts
Tim Whalen
David White
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
