Question about Sharp AR-405 Printer
Ar405 error code f2-31. how do i solve this problem I have the same issue, anyone have a "fix" it cam up right after we changed the toner Same problem, code F2-31 popped up after adding toner. I looked up the code and it is an "ID Pattern Reading Error". What does that mean and how do I fix it? Thanks!
    Problem Solver:
  • 11 Answers
Content Process control trouble (OPC drum
surface reflection rate abnormality)
Detail Usually the sensor gain is adjusted so
that the output is a certain value, by
reading the drum base surface with the
image density sensor before starting
process control.
However, a certain output is not obtained
by adjusting the sensor gain.
Cause Image density sensor defective
Check Check process control sensor output with
SIM44-2. (Do not adjust)
and
remedy If the result is far different from the
specified value, it suggests the sensor is
defective. Check the sensor and harness.
If the deviation is relatively small, check
the sensor and drum surface for
contamination.
Posted on Oct 05, 2009
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I have a Sharp AR-163 copier and it flashs U2 40. Does anyone know what the problem is?
Most commonly a toner cartridge issue. First try removing then reinstalling the toner cartridge and power off the machine. If this does not solve your issue then reset the error using the following:
Press these keys in sequence: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, press print, it will ask are you sure? press yes.
This will reset the code so you can see if the code comes back
If it does then you have to change the toner, it has a defective crum (counter chip) on the back of it
Oct 21, 2009 | Sharp AR 163 Copier
0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Office Equipment & Supplies
process control.
and
contamination.
Jun 01, 2009 | Sharp AR-405 Printer
problem sharp AR 405 copier error code f2-31 copier. How do i solve this problem.
Sep 09, 2008 | Sharp Office Equipment & Supplies
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
