Question about Kitchen Ranges
Range is shorting out and is tripping the circuit breaker
Our Frigidaire electric slide-in range has a short in it. We had an electrician come because the the range trips the circuit breaker after it has been on for awhile. When the electrician was here, he had all of the elements and the oven on and he said he saw an "arch" through the ceramic glass cooktop. Is this an easy repair and is it something that we could attempt to do ourselves? The range is only 5 years old. Thank you for any assistance you could offer.
  • 10,865 Answers
When the unit has cooled down, try to find exactly where the sparks came from.
If the sparks came from an obvious place like the surface burner heating elements or the bake/broil element, repair or replace any defective component you find. If you can't locate the place the sparks came from--or can't fix the problem yourself--contact a qualified appliance repair technician.
Posted on Jun 02, 2009
My Amana electric stove top popped and i saw a red flash from the burner i turned on. This happened twice. The breaker tripped each time. What could have caused this? It has never happened before.
There is a short circuit problem/fault with your electric stove. Short means both live and neutral cables are connecting together at some point I.e. with no load in-between them.
Have an electrician help check things out for you.
Oct 14, 2017 | Amana Kitchen Ranges
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
Tripping circuit breaker
please follow this steps and fix it. Otherwise call some electrician. God bless you
The circuit trips again. 2 issues could be causing this:
  • Overloaded circuit: Use fewer devices simultaneously or try moving certain devices or small appliances to a different area (use another outlet and circuit). Try resetting.
  • Electrical short: If your circuit is not overloaded, but the circuit keeps tripping, then this is likely the problem. The appliance or electronic device could be causing this short, or there could be faulty wiring in the walls. Consult a qualified electrician.
Oct 28, 2013 | Kitchen Appliances - Others
Just installed Fridg. Gallery convection range
The PF code stands for "Power Failure". This code will appear whenever the power is disrupted to the range. Pressing the cancel button on the touch panel should clear this code. Now it sounds like there is either an electrical short on the range or a problem with your GFCI electrical outlet/breaker. There is an internal fuse that might have burned out inside the range to prevent further electrical damage or the ERC/touch panel may have shorted out. The problem is if you start tinkering with the range and it is brand new then you might void the factory warranty by trying to repair it yourself. I would leave it unplugged and call the manufacturer or the place that you purchased it from and describe your problem. There might be a recall on that model range or a problem that they are aware of. You also might want to try plugging a couple other appliances into the SAME electrical outlet plug that you used for the range and see if the breaker/GFCI trips. If it does then the problem might be with the electrical plug or circuit. A bad plug or circuit can cause damage to an appliance(like the range) so be careful with any other appliances you use to test the outlet because they could be damaged also if the circuit or plug is bad.
Apr 17, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire self cleaning electric oven. I heard a two pops and this tripped the circuit breaker. I can't reset the circuit breaker because the pops occur again and trip the breaker again. Any...
Sounds like a shorted wire or something grounding.
Slide out range and unplug and take off bake and look around for a short either at the bake or broil element ot at the terminal where the cord connects.
Oct 01, 2009 | Kitchen Ranges
Maytag Performa Electric Range (PER1510) tripped circuit breaker when immediately following turning the oven on. There was a mild electric burn smell from behind the range. I have left the circuit...
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Aug 20, 2009 | Maytag PER5710 Performa Electric Kitchen...
Throws breaker when turn oven on
is it a new larger stove,then it could be a power supply deficiency,otherwise an element is bad or shorting to unit case and causing a trip
Aug 14, 2009 | Frigidaire FEF375E Electric Kitchen Range
My electric range is tripping the circuit breaker
unplug the unit and see if maybe you have a problem in the breaker/supply line from the house panel, otherwise does it work fine?,there also may be a bare or shorted wire in the unit itself
Aug 09, 2009 | Kitchen Ranges
Electrican Question - For a School Paper Not a Real Scenario
In my opinion turning on circuit breaker first is ok. First to determine what is tripping the breaker. Isolate what is on that circuit. There are always different ways of troubleshooting.
Mar 23, 2008 | Heating & Cooling
Kitchen Ranges Logo
254 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
