Question about LG VX4650 Cellular Phone
LV VX 4650 will not fully charge.
I have a LG VX4650 with a 1700mAh battery. When I plug the unit in to recharge it will display charge complete. The battery meter only one or two bars.
Battery no longer can hold a charge. Replace with a new battery (Ebay has them for cheap)
Posted on Sep 07, 2009
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Apr 08, 2015 | Tracfone Wireless LG 440G
Why doesn't the motorola P4000 not hold a charge after charging it for several hours
Your battery is shot. Rechargeable batteries only last so long.
Feb 08, 2015 | Motorola Cell Phones
How do I revive a Hilti 36 volt battery from a TE6 nicdm
There is no way to revive a rechargeable battery once they go bad. Rechargeable batteries have a lifespan that is affected by how many times they have been discharged and recharged and how fully discharged they are between recharges. Most batteries will last longer if they are fully discharged before recharging and allowed to cool completely before recharging, heat being the main culprit to their longgevity. They will eventually reach a point where they will not charge anymore or if they do they will not hold a full charge for any appreciable time. The best test for the batteries ability to take a charge is to completely deplete the battery either through working it or sitting on the couch with the trigger pulled until it stops working completely, let it cool down then put it in the charger. If it charges, use it to see how long it lasts. If it dies quickly it needs to be replaced.
Dec 29, 2011 | Drills
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Once the unit is charged how long does the battery run dry
Once fully charged, it will last for about 4 hours, if it is used without shutting down. The good thing is that it comes with a rechargeable lithium ion battery. That can be recharged once it is weak. I will strongly advice that you do not allow the battery run down completely before recharging as the battery might become weak and unable to hold a charge. So do not let your gps die before recharging. you can charge once it is low.
Dec 24, 2010 | Nextar X3-03 Car GPS Receiver
CHARGING
Seems like your phones battery is weak. Try these to increase the battery timings:
  • Let your phone to completely draw its battery, once its fully uncharged then recharge it completely and then use it. That will prolong the talk time and battery life too.
  • Lower the brightness of your phone, that will result in less consumption of battery.
  • If it does not helps then consider buying a new battery, but hopefully that wont be needed.
Thank You!
Jul 07, 2010 | LG Vu CU920 Cellular Phone
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
LG VX8700 won't stay charged...
I had the same problem with mine... I found that you must let the battery completely drain out; I was continuously jumping to charge my phone when it was down to one bar, and realized that upon doing this, the battery never fully retains its charge for as long as it will if you let it die out (blank screen; completely off).
I did this twice, and have not had a problem since.
Hope that helps!
Christina
Nov 25, 2008 | LG VX-8700 Cellular Phone
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
LG VX4650 Cellular Phone Logo
107 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
