Question about Refrigerators
Refrigetor doesn't freezer
My refrigetor runs with out freon and i want to add freon but i can't find the place where to put it.
  • 15,935 Answers
Small appliances use CLOSED systems because they use r-12 or 134a freon (you have to be licensed to buy and dispose of it) - once charged - they are sealed shut. You will have to make your own charging port with a tap (similar to a refrigerator water line tap. They are available at most A/C supply shops... however the taps are inconsequential if you do not have a license to purchase the refrigerant.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 02, 2009
Why is my Samsung french door/freezer not working
It is very rare to have a freon leak. It is possible but there are there are things that can cause the refrigerator not to get cold. Is the compressor running. Are the fans running. Is the freezer or refrigerator coils blocked with ice. Usually freon is the last place i look.
Jul 23, 2014 | Samsung RF265AA Bottom Freezer French Door...
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
Oct 26, 2013 | Amana 19.7 cu. ft. / 558 liter Upright...
My freezer is low on freon. And I don't see ports to attach to and add freon. Are there ports put on during assembly or do I need to add those on myself. My freezer model number is MSD2651HEB. Thanks...
Please tell me if you have not been able to attach gauges to determine that its low on REFRIGERANT how doyou know for absolutly sure its low??
Sep 11, 2011 | Maytag Refrigerators
Whirpool refrigetor compresser run for a few second and turn off
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Whirlpool Refrigerators
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
Freezer is not getting cool
Most likely if you have to ask this question it is better you do not try it as it requires that you add a service valve and need 134a service gauges and know how to read the gauges and know how to handle freon as it requires a license to safely handle this chemical.
you should look for other causes for no cooling, as is, is the compressor running? Are the cooling fans running or do you have a defrost problem that is evident by frost showing on the back side of the freezer?
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
