Question about Victor Office Equipment & Supplies
How do I install a ribbon in a 2640 victor adding machine
Swintec 2640 Typing wrong characters
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
DickyO
Mar 17, 2014 | Swintec 2640 Electronic Display Typewriter
Have a victor 1230-3 calculator / adding machine and my 2 year old grandson erased the tax and i cannot figure out how to get the 5% tax rate back in it.
1. Set the [GT OFF/GT ON/ TAX SET] switch to "TAX SET" position to select set mode for the tax rate.
2. Press "5"
Jun 17, 2011 | Victor 1230-2 Calculator
Simple math - $200.00 times 22 LCD shows correct $4400.00 Print out shows - $100.00 times 22 equals $4300.00
Sounds like you could have $100.00 in your memory. The LCD will show your current calculation but the print out might include anything you added to M+/-. Try clearing your M*
Jun 17, 2010 | Victor 2640 Calculator
How much would a water pump cost for a 1992 audi s100
here is a list from autozone depending on the engine model.
Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $192.99 Part No. 8811 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $195.99
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140131_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140139_edb_8851_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8851 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $203.29
Edelbrock Victor Series Water Pumpadd_to_bag.png CI_ItemIDs[itemCounter] = '17140139_true_298221_1992|Audi|100 S'; itemCounter = itemCounter + 1; 17140523_edb_8805_pri_thmb.jpg Edelbrock Victor Series Water PumpPart No. 8805 Warranty: 90 DAY REPLACEMENT IF DEFECTIVE $206.39
Apr 14, 2010 | 1992 Audi 100
I can't seem to do simple subtraction with my Victor 1208-2. When I subtract say 5-4, I get a negative 9. Is there a setting or do I need to press something different to get simple subtraction to work?
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sep 25, 2009 | Victor 1208-2 Calculator
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Setting the time & date on model # 2640
Here is the manual: Click Here
You need this program to read it: Click Here
Mar 24, 2009 | Victor 2640 Calculator
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Aug 08, 2008 | Swintec 7040 Typewriter
Adding machine ribbon foul up
how to install ribbion in adding machine
Dec 08, 2007 | Office Equipment & Supplies
306 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
k24674
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
