Question about Palm LifeDrive Handheld
Palm LifeDrive dead
Palm Lifedrive intermittently crashes.  It will stay off for a couple of days and then the next time I do a reset or turn it on it  will begin to operate again. It may work for a couple of days or a couple of minutes and then will go black again and not even respond to a reset.  I have at one point done a hard reset and removed and reinstalled all of the data with a sync but still get many of the same symptoms.  Currently the device is non responsive – it had started to boot again and I interrupted with an attempted hard reset and it just blacked out.  Is this a motherboard or a switch?  Have you seen these symptoms before?
  • 2 more comments
  • nickp48 Nov 03, 2007
    I'm having the same problem. Thought it might be battery, replaced that, it worked fine for a couple of weeks then started crashing out again. Occasionally I could do a soft reboot, sometimes unplugging and replugging the battery worked, sometimes nothing would get it to reboot, once it went into a reboot loop and just kept rebooting til I switched it off. At Palm's tech support suggestion I managed to fire it up and do a complete erase of the hard drive and reload all from backup, but then it just crashed out again.
    Switch, hard drive, or motherboard faulty? Any suggestions welcome. I certainly will never buy another Palm product, just hope to get this one working again.
  • danyal68 Dec 10, 2007
    Audible click, LifeDrive goes into reboot loop, then dies. Tried soft and hard reset, full battery drain & recharge. No luck--any suggestions?
  • 0220 Jun 24, 2008
    lifedrive crashes, cant be turned on. permanently dead
  • nickp48 Nov 27, 2013
    It's been six uears since I posted this, new motherboard and battery fixed the problem and its still working fine.
  • 3 Answers
I tired both those links and even entering the case number but kept getting an "invalid" message.
I ended up getting a new motherboard as that was the only possible remaining cause of the problem (keyboard, screen, hard drive, etc. all work fine). After installing that, it seems to be going ok for the past two weeks. The original battery was stuffed, it only holds a charge for a day or two, so that was part of the problem but something on the motherboard was also dodgy. I'm convinced now that these products are a failure and that is why Palm have abandoned them.
Posted on Jan 07, 2008
  • nickp48 Dec 28, 2008
    The lifedrive has been working just fine for a year now (touching wood as I write this), and I switched back to the original battery which also works ok. There was clearly a fault with the motherboard which made it think the battery was flat when it wasn't. I'd say, if it keeps rebooting, or boots then shuts off, and the hard drive appears to be working, then the motherboard is the most likely problem.
  • 59 Answers
You may be stuck in a loop-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=2,E=0000000000825355002,K=8658,Sxi=6,Case=Obj(26419)
After you do a hard reset, try naming the palm something other than what the name was before hand and see if that profile works.
SOURCE:
It reset and is now stuck on the 1st lifedrive screen and wont go any further
HI there,
Normal 0 The best thing I can offer for you to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Here is that link.....
Normal 0 http://kb.palm.com/wps/portal/kb/na/lifedrive/lifedrive/unlocked/supportservices/page_en.html
Nov 23, 2009 | Palm LifeDrive Mobile Manager Handheld
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
Battery not holding a charge, maybe...
The only thing close that I can recommend is doing an in cradle reset. Palms site says it only works on certain models, but hey it's worth a shot.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Nov 26, 2007 | Palm LifeDrive Handheld
LifeDrive Not Responding
Here is the only thing I found related to your issue-
Nov 10, 2007 | Palm LifeDrive Handheld
Lifedrive sick
Try a hard reset and if that doesn't work ( the erase program hangs up), then your hard drive is dead and must be replaced.
Nov 10, 2007 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive
just press the time in the top left hand corner of the lifedrive and a dropdown menu comes down with the option "delete" but this is only for apps. if you want to delete media files, search for a file manager on freewarepalm.com
Apr 21, 2007 | Palm LifeDrive Handheld
Dead; will not boot up
I to have the same problem. Palm will switch a refurbished on to me for $175. To talk ot their tech support will cost $25. I have decided to do 1 of 2 things. 1. replace the microdrive with a 4Gb Compact flash and if that is not successful, just throw it away and NEVER get another Palm product. Mine died just after the warranty ran out. 12 months plus a few days.
Sep 10, 2006 | Palm LifeDrive Mobile Manager Handheld
Dead Lifedrive
I im not mistaking this unit has a 1 year warrantee. I would contact the #v below to see how to get this back up and alive. Good luck 847-262-PALM
Apr 15, 2006 | Palm LifeDrive Mobile Manager Handheld
Wikipedia with lifedrive?
tr3 files are desktop PC files, they must be converted to .pdb files by the TomeRaider desktop program. Changing the file extention does not convert the data to Palm format, it is still PC data.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
674 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
