Question about Panasonic Televison & Video
VCR keeps showing "F03" and doens't do anything
The VCR screen always springs back to "F03" after a couple of seconds and I'm not able to do anything then. I tried like every button on the remote, but nothing helps. Even when I let the VCR play, he doesn't even start, just makes some noice and then the screen says "F03" again
  • Panasonic Master
  • 5,113 Answers
Your vcr seems to use the K Mech. F03 Means that the mechanism locks when unloading.
The cause of which might be the loading motor or drive, timing and most likely the mode switch.
Posted on Jun 16, 2009
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Panasonic HS900 VCR. Switch on and F03 fault appears.
You have a model that uses the K-Deck look that up using google for further information.
However F03 means locks when unloading. There are several causes of this: The Load motor or drive, timing, or the mode switch.
Aug 17, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Ipod keep freezing with only the apple showing on screen...wont do anything else...says port is not found
1) Start iTunes.
2) Power the device on by holding the sleep/wake and home button for about 10 seconds. Release the sleep/wake button, but keep holding the home button.
3) If you did it correctly, the device will be showing either a connect to itunes screen (recovery mode) or a black screen (DFU mode) We are trying for DFU mode here, but recovery may work too. Connect the ipod to your computer. iTunes will tell you that it has detected an iPhone or iPod touch in recovery mode.
4) If you see the iTunes icon and cable on your iPhone, your device is not in DFU mode, but in recovery mode. Your device's screen will be black when you are in DFU mode. I always have to try this several times so succeed.
5) Connect your device back to your Pc/Mac and press SHIFT+CLICK (pc) or COMMAND+ CLICK on the restore button.
6) Select the firmware version you'd like to install from your computer. You can google for ipod touch firmare to download the file, or just let it update right from apple.
7) Wait for a couple of minutes and your iPhone/iPod will be as new.
Jan 07, 2011 | Apple iPod touch
I'm trying to transfer VHS film from my Daewoo VCR into my computer to copy it onto a DVD. HI FI flashes on the screen a couple of times and stays for about 10 seconds. How do I get rid of this?
It's an screen display for the Hi-Fi sound playing. However it should only come on when first starting. If it keeps popping up during playback it means that the Hi-Fi sound is dropping out then coming back on. This is often caused by poor tracking or the result of dirt on the video head. Clean the head and see if that solves the problem. If you are doing a lot of tapes keep cleaning it. Few video's have the option to remove on-screen displays. However if they do it will be on the menu somewhere.
Dec 11, 2010 | Daewoo DV-T8DN VHS VCR
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error F03
F03 is a loading mechanism error. look for something obstructing the loading arms in the mechanism - a label from a tape, a piece from a broken cassette, etc.
May 08, 2008 | Panasonic AG-DV2000 Mini DV VCR
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
Sony KV34HS420
Always go through the basics before you post questions.  All I did was reset the TV (unplug for a few minutes) and it is back to normal.  Lesson learned, TV fixed, thanks.
Feb 15, 2008 | Televison & Video
Error Code F03
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
523 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
