Question about Toshiba Satellite A135-S4527 Notebook
AC Adapter dosen't work
I'll try to start my satellie A-135 S4527 (Toshiba) notebook but dosen't work, I changed the battery but still dead. I plug the AC Adapter in the computer trying to charge the battery but I can't see the light on in the computer. I don't know what else I can do. Pl. help me. Thanks
    Scholar:
  • 156 Answers
Check if there is a green light on the Adapter, on the black Box, if it is not there, please get a new adapter
Posted on Jun 02, 2009
  • 674 Answers
Check first the charger use the analog or digital tester to test the charger if working or not.. power cored and charger itself.. then if now working use another charger.. but should be the same voltage.. .. then check also the laptop if working in another charger because somtime the DC jack connector is affected that why the charge sometime not work cause of that
if the laptop there is no ligth it means the laptop also has problem of the power connection,... let checak open the laptop then fix it
thanks
My battery won't charge why not
If it's connected properly, that sounds like a dead battery. Try wrapping it in something waterproof and freezing it overnight. If that doesn't work, replace it.
Apr 06, 2011 | Toshiba Satellite A135-S4527 Notebook
I have a Toshiba Satellite A135-S4527 and it will not turn on. I checked the AC adapter and I am getting 19 Volts and my laptop shows that i have power going to the laptop but yet it will not turn on.
Welcome to Fixya.
It seems like you are experiencing a "No power/no post" issue on your laptop, here are my recommendations :
  • Disconnect everything attached to your laptop (USB cables, etc)
  • Disconnect the ac adapter
  • Carefully remove the laptop's battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter to laptop without the battery and turn it on
  • If this works, return the battery to the laptop and try it again with the ac adapter
If none of the above procedure works, then the laptop needs to be serviced. I've included Toshiba's support contacts below for your further reference :
Toshiba Support
Hope this helps and Thanks for using Fixya.
Jan 22, 2011 | Toshiba Satellite A135-S4527 Notebook
I replaced the RTC battery in my Toshiba Satellie P105 because the clock was losing time. When I restarted, the hard drive and fan would cycle on/off, black screen, no beeps. After a couple of minutes,...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 21, 2010 | Toshiba Computers & Internet
When I plug the AC plug into my computer, the battery light doesn't appear that it's charging. I purchased a new battery and still doesnt charge. any ideas?
try to darin the batter first. heres the procedure. take out the battery and unplugged the power adapter. press and hold the power button for 30secs. after 30 sces, put the battery and adapter back in. then power on the computer and observe.
Apr 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Plugged in not chargin
Try power drain.
1.take the battery out n disconnect from the external power .
2. Hold on to the power button for 30 sec .
3.Try connect to external power source(AC adapter) without battery.
4.Later u can put the battery back and use as usual.
Mar 26, 2010 | Toshiba Satellite A135-S4527 Notebook
Unable to start the computer. power button will light up for a second but no fans or other noises and then the light goes off
i would say try replacing the battery or the ac adapter. I had the same exact problem on my toshiba a105-s171. my battery was dead because the ac adapter failed to charge. Replaced the adapter and it works now.
Jan 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Lap top will not start up
First that u need to do is to remove the battery from your toshiba laptop. Plug in the AC adapter alone and power it on. If it works, then u need to check your battery. If the notebook wont power on with the AC adapter alone, then i think its a NO POST issue. The motherboard needs to be checked.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Wont shutdown or hybernate on ac adapter, ok on battery
You might need to do a system restore from an earlier time from tools menue in accessories/or use a recovery cd/or format your HD
Aug 14, 2008 | Toshiba Satellite A135-S4527 Notebook
No power
Try removing your battery and then plugging in the AC adapter. The damage could also be to the motherboard or PSU. So keep that in mind but you may be able to get it slightly operational by removing the battery.
Jun 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
