Question about Freezers
After freezer was moved not getting cold
I moved to new location and freezer worked fine i got to my new apartment and plugged it in and it just defrost and wont get cold there is no sounds coming from the sears coldspot upright freezer model no 106.720120
  • Anonymous Mar 24, 2014
    Need to replace the door gasket, part no. 586977, on a Sears freezer model no. 198715610. Is it available anywhere?
  • 142 Answers
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Posted on Jun 03, 2009
    Problem Solver:
  • 10 Answers
Be sure the unit is upright in the normal position. They don't like starting right after they have been moved or on their side, until all their fluids have settled properly.
Posted on Oct 03, 2012
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Moved. freezer worked but won't work at new location.
Hi friend, thank you for your post!
I understand that your Frigidaire freezer is currently not working in the new outlet. I would adjust the temperature to a lower setting to see if that would start the compressor to start cooling. Is your appliance getting power to it? If you could provide feedback regarding your appliance I would like to provide see what additional information I can provide you. -Matt
Sep 06, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
Can I move this freezer on its side? Driving time is abot 2.5 hours.
Yes you can move the freezer on its side. Just make sure that when you get it to the new location to let it stand up for a min of 24 hrs before you plug it in.
Good luck and please rate 4 thumbs up for the free answer.
Jul 29, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Freezers Logo
293 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
